Radiator hose leak
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by silverspur, Dec 14, 2020.
  1. silverspur
    silverspur Road Train Member
    1,760
    8,153
    Sep 26, 2012
    2019 International LT, leaking radiator hose (beneath the fan).
    Is this a hard fix for a roadside repair? How much fluid will spill when the hose comes off?
    Thanks
    truckdriver31 Thanks this.
  3. AModelCat
    164,663
    Everything in the cooling system is going to puke out if you remove the hose.
    Honestly, try the clamp and see if its loose. No need to crank hard on it if its a plastic rad tank as they can crack.
  4. silverspur
    1,760
    8,153
    Sep 26, 2012
    Ok
  5. IH Truck Guy
    4,945
    57,422
    Mar 2, 2008
    Purgatory
    Can't tighten that type of clamp
  6. Judge
    92,016
    What you have now.
    What you’ll have if the clamp breaks from over tightening.
    baha, truckdriver31 and silverspur Thank this.
  7. silverspur
    1,760
    8,153
    Sep 26, 2012
    The metal clamp takes a screw driver. Kind of hard to get to. I'm in St. Paul so I can try it in the morning.
  8. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    they have a known issue with the 19/20 rad hoses blowing off. international is aware of it
    silverspur Thanks this.
  9. IH Truck Guy
    4,945
    57,422
    Mar 2, 2008
    Purgatory
    Ah,from the small pic on my phone it looked like a ring clamp.
  10. AModelCat
    164,663
    Should be able to. I can see part of the clamp's tail sticking out in the one picture.
  11. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    If you have room add another clamp right next to it. Put the worm screw 180 degrees from the other one.
