Reefer help
Discussion in 'Refrigerated Trucking Forum' started by mongo95, Mar 26, 2025.
  1. mongo95
    mongo95 Bobtail Member
    4
    Mar 26, 2025
    Carrying ice cream
    Temp set to -20 and continuous said by shipper
    Box temp stays around 1-3 and doesn’t change any lower
    77 degrees out side sun is out no clouds
    What should I do? Is it normal?
    edit: im new to reefer
  3. bad-luck
    bad-luck Road Train Member
    3,439
    6,332
    Nov 16, 2013
    Baltimore, Maryland
    Were you pre-cooled to -20 before you got loaded? Icecream is at -20 when they load it, so your unit should be somewhere close to -20
  4. hope not dumb twucker
    6,139
    53,428
    Aug 23, 2022
    Hope pray that a sensor or two is wrong. And that they didn’t put temp recorders in there. But they probably did.
    motocross25 and Lennythedriver Thank this.
  5. Lennythedriver
    Lennythedriver Road Train Member
    2,411
    8,228
    Feb 14, 2020
    Ice cream almost always get a temp sensor. If it slightly defrosts and refreezes, it’s no good. If he’s staying around zero, might be ok, but if it runs that way too long, it’ll get rejected.
  6. mongo95
    4
    Mar 26, 2025
    Pre cooled on the way there showed up at -10
    hope not dumb twucker Thanks this.
  7. hope not dumb twucker
    6,139
    53,428
    Aug 23, 2022
  8. mongo95
    4
    Mar 26, 2025
    Just on this load it started maybe an hour and a half after picking up
  9. hope not dumb twucker
    6,139
    53,428
    Aug 23, 2022
    Every time I have it there’s a recorder in there.
  10. bad-luck
    3,439
    6,332
    Nov 16, 2013
    Baltimore, Maryland
    Ok. As I mentioned icecream is loaded at -20. If you were pre-cooled to -10, you should be close to -20. Only reason you would be above 0 is if you just came out of defrost. Icecream is a VERY sensitive product to haul. If you are staying above 0, you are going to have an issue when your unit starts defrost
  11. mongo95
    4
    Mar 26, 2025
    Yeah I’m waiting on a call back from my maintenance. It’s staying around 3 degrees right now
