reefer load?
Discussion in 'Refrigerated Trucking Forum' started by cavtruck, Aug 14, 2021.
  1. cavtruck
    cavtruck Bobtail Member
    18
    Jul 30, 2021
    Hi
    what happens when a reefer load gets refused?
    who is responsible for it? pays for moving it somewhere else. etc.
  3. 062
    062 Road Train Member
    6,342
    33,999
    Oct 20, 2013
    It depends on what it is and who’s at fault. I’ve had shippers send product that was out of date that had to be trashed. I’ve had wilted spinach that was my fault. It was deducted from the load pay and I owned it.
    Team818 Thanks this.
  4. Team818
    Team818 Medium Load Member
    397
    628
    May 5, 2019
    Not sure, but there are load insurances going on in the movement of fresh produce, fruits, fresh meats can be switched to now being a frozen meat, but that is really not my expertise. I am going to be working for a Refrigeration Co soon. Orientation is Mon or Tue the 16th. UA, driving test, meet everybody. Very tiny company. I can sit and talk with the Owner as long as he is not too busy.
    Speed_Drums Thanks this.
  5. ranger2.3t
    ranger2.3t Bobtail Member
    14
    13
    Sep 5, 2021
    Had a load of yogurt where one pallet was refused because it was loaded on error. Talked to the broker the cost of bringing it back exceed the value of the product, so the yogurt was donated
    alds and Speed_Drums Thank this.
  6. ranger2.3t
    14
    13
    Sep 5, 2021
    Always get a receipt for the donation
  7. Priority Freight LLC
    Priority Freight LLC Bobtail Member
    20
    7
    Feb 20, 2019
    Grand Rapids, MI
    It depends but if you run your reefer at the correct temperature and load is secured then you should not be responsible. Sometimes produce is rejected due to quality or some boxes get crushed. In that case the customer/broker has to pay to take it back or deliver to another location, and you can usually negotiate a rate that you want just be reasonable.
  8. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Actually none of what anyone claims so far matters. All that matters is what is in the contract (rate con, carrier packet, etc.) As you, or your carrier are that ones who signed the contract only you or your carrier can answer that question.
    What others are talking about may or may not be common practice, they are by no means guaranteed.
  9. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    If anyone can, they will pin it on the driver first. Get everything in writing, and a new rate con before you move. I got stuck with pineapples for a week because they were not sweet enough...
    alds Thanks this.
  10. rakusa
    rakusa Light Load Member
    173
    30
    Nov 13, 2005
    So they did a taste test before unloading?
  11. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    Brix test.
