Reefer Temp Control in Winter
Discussion in 'Refrigerated Trucking Forum' started by ZzYy, Jan 6, 2012.
  1. ZzYy
    ZzYy Bobtail Member
    5
    Jan 6, 2012
    Atlanta
    Sorry for my ignorance, but I couldn't get a straight answer from my carrier. If a 72' reefer trailer (with a ThermoKing) is configured with the front half being frozen ie 28 degrees or below and the back half being 'not frozen' ie 34 degrees, then if the ambient outdoor temperature is 5 degrees for more than 2 hours, how can the ThermoKing keep the 'not frozen' half from going below 34 degrees when it is mounted at the opposite end ?
    Maybe I should buy a book on thermodynamics, but I thought I would ask an expert.
    Thanks
  3. Winchester Magnum
    Winchester Magnum Road Train Member
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    The unit will heat. Just like if the whole trailer was loaded with tomatos set at 55 degrees and you were running in -30 outside temps, the unit will heat.
  4. 123456
    123456 Road Train Member
    10,555
    5,748
    Oct 22, 2010
    32179
    Nice long trailer :biggrin_255:
  5. rogueunh
    rogueunh Road Train Member
    1,086
    23,065
    Jan 4, 2011
    I've been thinking of trading one of my 48's in for a 72. Just to try something different.......
  6. SmoothShifter
    SmoothShifter Defender of the Driveline
    561
    581
    Sep 10, 2010
    Feura Bush, NY
    72' trailer, eh?
    Assuming you are running a dual zone TK unit, both units will heat from a -5 degree standpoint to a certain set-point.
    I'm not 100% sure that you can leave the front unit off and heat the rear compartment only, because I never was in that situation. I would almost recommend running the frozen at near recommended temperature, in the event that heated air from compartment #2 leaks into the front.
    My dual zone units always had sub-zero frozen in the nose and fresh in the second compartment.
  7. ZzYy
    ZzYy Bobtail Member
    5
    Jan 6, 2012
    Atlanta
    Thanks very much for the replies. I guess I should have put a ;-) next to 72'. Would make turning a corner fun.
    123456 Thanks this.
  8. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Plus trying to freeze 34 deg product with 28 degree air would probably take 2-3 days to adjust out. If I had ice cream up front and banana's in the back, I would be a little worried. :)
  9. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    I run split loads every week and just use a bulkhead to seperate the two temps. The times I have seen a true dual temp trailer used OTR or even regional the rear unit was damaged in one way or another from careless forklifts with tall pallets. The extra cost and maintaince of the second unti just didn't seem worht it when you consider a bulkhead only cost around $1000. The only way I would ever consider a rear unit would be a dedicated run where the frozen had to be on the rear.
    The Challenger Thanks this.
  10. ZzYy
    ZzYy Bobtail Member
    5
    Jan 6, 2012
    Atlanta
    The thing I can't grasp is, if you are partitioned and the ThermoKing is cab end, and the cab end is the frozen half, then if it 10 degrees outside, how can the refrigerated end be kept at 34 degrees ? If you are heating (slightly) the frozen part if at all, how can the back be kept at 34 degrees ?
  11. cuzzin it
    cuzzin it Road Train Member
    3,643
    12,581
    Jan 19, 2008
    Berea, KY
    i wonder if New York Triple charges of the turnpike for a 72
