Reefer unit fuel burn rate?
Discussion in 'Refrigerated Trucking Forum' started by turboguy, Mar 5, 2018.
  1. turboguy
    turboguy Light Load Member
    138
    27
    May 16, 2015
    hey guys
    Im looking at getting into refrigerated freight, I have a direct shipper I can work with for good rates.
    Im doing my due diligence right now and putting a proforma together.
    I was wondering what the fuel burn rate is on the generator?
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    what generator?
  4. turboguy
    138
    27
    May 16, 2015
    the reefer unit "generator"
  5. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    my friend its not a "generator". it's more like air conditioner.
    xlsdraw, MachoCyclone and KB3MMX Thank this.
  6. dptrucker
    dptrucker Road Train Member
    4,760
    3,319
    May 14, 2012
    adelanto,ca.
    Reefer unit not a generator but an a.c. and heater unit that is run off a 50 gal diesel tank and has a battery to help start
    KB3MMX and Frank Speak Thank this.
  7. turboguy
    138
    27
    May 16, 2015
    yes but it has an engine to run that air conditioner
  8. thelushlarry
    thelushlarry Road Train Member
    3,023
    9,003
    Jan 9, 2012
    glasgow ky
    I always heard the slower you drive the less fuel you will use.
  9. turboguy
    138
    27
    May 16, 2015
    thanks for the help
  10. STexan
    STexan Road Train Member
    14,963
    29,179
    Oct 3, 2011
    Longview, TX
    Roughly speaking and with a newer unit and 20 gallons of fuel you might figure a start stop frozen load might go 4 days in mild temps. A continuous chilled load might only run about 48 hours on the same 20 gallons.
    But your biggest concern should be depreciation (note, rental, etc) cost and maintenance budgeting for when something goes wrong. Reefers aren't cheap, and if you find a "cheap" one, you better figure on lots of big surprise costs coming up every month.
    bzinger, KB3MMX and turboguy Thank this.
  11. turboguy
    138
    27
    May 16, 2015
    thank you @STexan for the helpful information.. I am going to lease one to start off with
