Reefer unit.
Discussion in 'Refrigerated Trucking Forum' started by maximo111, Jan 12, 2015.
  1. maximo111
    maximo111 Bobtail Member
    7
    Jul 22, 2014
    Fort worth, Texas
    Reefer showed alarm 37,low coolant. Tech said it was low on coolant. I saw him put like a gallon of thr red stuff,but most of it came back out thru the overflow hose. He did it again and same thing happen.
    What it happening here????????????????
    I saw the coolant temp.working ok on micro,so that tells me thermostat is doing its job.
    Reservoir cap is new. HELP!
  3. FLATBED
    FLATBED Road Train Member
    Bad coolant level sensor
  4. rogueunh
    rogueunh Road Train Member
    1,086
    23,192
    Jan 4, 2011
    Agree with above, most likely a sensor.
  5. maximo111
    7
    Jul 22, 2014
    Fort worth, Texas
    Hello there. The coolant alrm switch is ok,reason I say that due to level being under the switch mark. It just keeps vomiting the coolant everytime you refill.
    Thanks
  6. 201
    201 Road Train Member
    12,878
    26,508
    Apr 16, 2014
    high plains colorado
    Hi FLATBED, dang, I knew I should have gone into the sensor business. I remember when reefers were so simple, noisy, but simple. Aside from sucking the fuel dry, which can still be a problem, the worst that could happen was that big fan belt would fly off.
    jbatmick Thanks this.
  7. Badcable
    Badcable Medium Load Member
    356
    191
    Feb 1, 2008
    Outside Chicago, IL
    Agreeing with the other guys on a coolant level sensor. Or - crap in the wire connectors, tis the season.
  8. 404a
    404a Bobtail Member
    23
    11
    Feb 28, 2015
    Delavan, WI
    Hey did you get this resolved? I would like to know what type of model this is?
  9. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Does it spit it out as soon as your pour it in...or after it runs awhile???And will it run w/alarm code or does code shut it down??
  10. 404a
    404a Bobtail Member
    23
    11
    Feb 28, 2015
    Delavan, WI
    Well hope you got it squared away, but if it is a tier 2 yanmar a blown head gasket is common.
