1. tarmadilo
    tarmadilo Road Train Member
    1,733
    4,777
    Dec 12, 2018
    I’ve been using an inexpensive Galanz dorm style fridge from Walmart in my International for the last year. Seriously the best $89.95 I’ve ever spent.
  3. Professor No-Name
    Professor No-Name Road Train Member
    4,045
    7,811
    Nov 26, 2016
    Yea i was gonna say they have a small square mini apartment size fridge at Walmart for a 100 bucks. The bigger one thats sorta retro fridge on bottom, freezer on top is maybe 150. Ya would have to take out the passenger seat for a good spot for the bigger one tho. We have a built in fridge in our volvo but we still run an extra plug in cooler for extra space.
  4. Short Fuse EOD
    2,791
    8,762
    Jul 29, 2015
    Midwest
    Dometic has the best warranty. They will make it right idle you ever have an issue during warranty. Also there are places in in northern Indiana that fix them after warranty. Good product.
  5. Judge
    93,003
  6. Professor No-Name
    4,045
    7,811
    Nov 26, 2016
    Why would ya spend several hundred for something when ya can buy a perfectly capable mini fridge at Walmart for a 100 bucks? Yea it's not gonna mount somewhere an look like it came from the factory that way but drivers have been using simple plain plug in coolers forever an ya just sit em wherever. The mini fridge would sit perfect in the passenger seat or on a board on an upper bunk an for a 100 bucks work just as good as the fancy ones everyone is talking about costing 600 to a 1000.
  7. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,266
    Nov 14, 2021
    ALBERTA
    Bee... is good, GOD is great and people are crazy.
    If I ever learned something in life, this is it.
    Professor No-Name Thanks this.
  8. bilbil1960
    bilbil1960 Bobtail Member
    14
    19
    Feb 4, 2022
    135.00 display model, she knocked off 30 buck.
    Microwave was 47
  9. Professor No-Name
    4,045
    7,811
    Nov 26, 2016
    Nice set up. An affordable.
  10. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    I've been using a cheap Alpicool from Amazon for years. It's been absolutely perfect. It's a real fridge with a compressor but it lays down like a cooler so I can slide it under my bunk or into a closet. I own a W9 but it should work in any truck and you can change vehicles with it easily.
  11. Rum
    Rum Bobtail Member
    29
    26
    Feb 22, 2019
    Ideally you'd invest in a 12v fridge that'll run 24/7 without the need of an inverter or the truck engine and apu running. Good ones will be whisper silent. If you can remove your passenger seat you can fit a large capacity Iceco dual frig freezer chest. Great if you like the idea of having usability outside of trucking for mobile camping/overlanding. Prices run around $300-$900 depending on the series. While your going through the hassle of removing the seat and plugging some holes you might as well consider carpentering a custom table over the cooler to increase your counter space since you'll want to be able to setup a cutting board and increase dining space. And since you've installed a fridge to store a month of food, you'll probably want something more than a low capacity microwave (junk food reheater). There's enough space left to build functional cabinets for better storage and the largest capacity air fryers on the market. But now at this point you will need to invest in a pure sine inverter with at least 3000 watts of juice.
    You can also obtain a 120v fridge from Walmart and Best Buy on the cheap and be a medium size with freezer and frig. These will emit and annoying buzzing sound. Just depends how much you care to tune the harmonics inside your sleeper. I don't mind white noise from the A/C but induce the buzzing from those fridges, I'll toss it out for a Yeti cooler and ice. Which is another functional option too. If your able to obtain dry ice it will last a long time.
