1. LilBudyWizer
    LilBudyWizer Light Load Member
    185
    169
    For those times when G.O.A.L. is getting a bit excessive. There's plenty of WIFI cameras which would have sufficient range, but many stream to the cloud which with video is going to be a bit of problem on a cellular data plan. I can throw a router to nowhere in the truck to avoid that, but it has to work with no internet connection. Also battery powered and rechargeable would be great.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    I don't care if there is a thousand cameras all over that rig.
    You will get out and LOOK. As in hop out and walk all the way back there and look.
    Your eyeball is the one device that determines if you hit im or not. And generally attached to your butt that gets the firing if you did not GOAL and hit something or someone.
    All the cameras and whizbang tech in the world wont save you or anyone if you got lazy and don't care.
    tinytim and RoadRooster Thank this.
  4. RoadRooster
    RoadRooster Road Train Member
    4,121
    6,710
    May 10, 2015
    Fort Myers, Florida
    What? Taking off pajamas and slippers to put on real clothes, just to goal, just to back into a hole?
    Don't think I am cut out for truck driving...sarcasm intended
    tscottme, tinytim and blairandgretchen Thank this.
  5. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    or actually put some clothing on, going commando sure puts a slow down on them DOT inspectors jumping in.
    RoadRooster Thanks this.
  6. Razorwyr
    Razorwyr Road Train Member
    2,284
    2,824
    Jul 27, 2010
    Meridian, Mississippi
    I do it just for the infrared cameras in oklahoma
  7. pmdriver
    2,338
    3,503
    Nov 14, 2017
    and then have playing:
  8. LilBudyWizer
    185
    169
    The idea was to still G.O.A.L. but things like blindside where there can be a whole lot of getting in and out. I wasn't thinking mounted on the tractor or trailer, but sitting on the ground. With the tandems forward I tend to shy towards the drivers side just to be safe when sometimes the overhand on the blindside didn't get within 5'.
  9. tinytim
    tinytim Road Train Member
    5,145
    19,380
    Oct 29, 2007
    Northern Ontario
    A baby monitor would do what you want.
    I'm with @x1Heavy though, an eyeball can't be beat. Just freakin' GOAL.
    tscottme and x1Heavy Thank this.
