Remote light on reefer
Discussion in 'Refrigerated Trucking Forum' started by ShortBusKid, Mar 15, 2014.
  1. ShortBusKid
    ShortBusKid Heavy Load Member
    955
    1,269
    Dec 5, 2010
    Vegas
    My remote light on the reefer went out this week. I've looked and don't see any obvious issues as to why it's not lighting up. The unit is running fine so I'm not super worried about it but I would like to fix it. Anybody have this issue and could give me an idea of where to start looking for the problem? The unit is a 2006 Carrier Ultima XTC with a 2012 motor and compressor. The new engine and compressor were installed by Carrier in October and the light has been working fine until about a week ago.
  3. buzzarddriver
    3,854
    11,703
    Feb 1, 2011
    Dallas, TX
    Could be something as simple as the plug for the remote has vibrated loose. Check to where the cable is connected inside the control panel of the unit to see if it is tight.
  4. wichris
    wichris Road Train Member
    4,522
    9,320
    Jan 17, 2011
    If it's the LED one look for a break anywhere the wiring makes a turn. Usually where it goes into the module so you can't repair it. They're a real PITA.
  5. MachoCyclone
    MachoCyclone Road Train Member
    4,417
    3,907
    Jun 13, 2012
    Texas
    If it is the one with the 8 different lights on it. Then could be the bulb is burnt out. Just use a long screwdriver and a pair of needle nose to unbolt the box from the trailer. You can the check the lights and most truck stops sells that size light in a package for 6 for $6
  6. Ann Eiffel
    Ann Eiffel Light Load Member
    89
    58
    Nov 13, 2013
    Ive learned to ignore the "quirks" of reefer operation status compliance update just gotta know thing-a-magingies. If the temps' consistent I get out the electrical tape to mask the offending warning light and bounce. No worries, mate!
  7. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    So if you are behind the wheel for hours running across the desert just ignore it? There are some codes that can wait while there are others you can't ignore.
    truckon, MachoCyclone and Balakov100 Thank this.
  8. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    The bulbs in the Carrier display are simply 198 wedge bulbs. I replaced mine with LED and they're much more noticeable, especially in direct sunlight.
  9. Ann Eiffel
    89
    58
    Nov 13, 2013
    No, I dont just ignore it. But I also know how to analize a "ghost in the machine" and not over think it. If its holding its temp I'm happy. My job is to deliver on time with a quality product. If I went to a Thermo King everytime a light flashed the only entity generating profit would be...wait for it...Thermo King!
  10. ahmadali04
    ahmadali04 Bobtail Member
    28
    6
    Jan 30, 2011
    Not sure if you got it fixed or not, but I had a similar problem on mine, and turned out to be the fuse. The fuse for the Ultima XTC is a 3amp fuse, and it is located underneath the reefer, (not the fuse box), in a housing, next to wiring for the light. The housing looks like a connecter. If you can't find let me know, I can try to take a picture.
  11. MNoutkast
    MNoutkast Medium Load Member
    441
    151
    Feb 24, 2012
    Elk River, MN
    Time to upgrade maybe? I don't think I have seen my unit code out in over a year. And the last time I can remember was because it was 100° out and was set at -10° and bumped to a dock with crappy pads for 12 hours.
