Remove air actuator from 5th wheel
Discussion in 'International Forum' started by Yoster, Jan 22, 2023.
  1. Yoster
    Yoster Light Load Member
    59
    66
    May 16, 2011
    Fort Smith, Arkansas
    Hey there, I've been getting annoyed with the frustrations of an air actuated fifth wheel release via in cab switch. I had a guy tell me that you could just remove that air cylinder and use it as a manual pull release. Is it really that simple? I was going to ask my mechanic to do it well I'm at home so I just wanted to make sure. Thanks.
  3. Judge
    93,253
  4. Yoster
    59
    66
    May 16, 2011
    It has already caused plenty of issues getting stuck, so I'm not waiting for something to go wrong worse down the line.
  5. wichris
    wichris Road Train Member
    4,533
    9,346
    Jan 17, 2011
    You can disconnect it. Or you can pull manually with it hooked up, just takes a lot more muscle to do it.
  6. Mnmover99
    Mnmover99 Light Load Member
    248
    344
    Oct 22, 2022
    You need to disconnect the air cylinder from the release rod, otherwise you are pulling against the air cylinder AND the release. Usually the air cylinder has a pin on one end that can be removed.
