Removing a stuck NOX outlet sensor
Discussion in 'Ask An Owner Operator' started by gekko1323, Feb 23, 2026.
  1. gekko1323
    gekko1323 Road Train Member
    1,668
    2,785
    Jul 14, 2018
    Henderson, NV
    Hey guys. The title of the thread is pretty self-explanatory. I'm trying to remove the outlet NOX sensor on my 2012 Volvo. The sucker won't budge. I even cracked a 7/8" wrench! Will a sensor socket help? PB Blaster? Torch? As always, thanks for the feedback.
  3. JB7
    JB7 Road Train Member
    1,037
    1,830
    Dec 13, 2022
    Laurel, MD
    You could have the truck at operating temperature and then try a sensor socket with a long breaker bar or ratchet.
    When cold spray blaster on there several times over several hours and let sit overnight.
    Heat the area with a torch.
    FYI on this tool. I don't see the components sold individually.
    Milton Industries LT996D Milton Shockit Socket Sensor Removal Kits | Summit Racing
    Sometimes the bung (what the sensor screws into) needs to be replaced.
  4. Big Road Skateboard
    7,195
    40,852
    May 2, 2021
    I'll sometimes cut the sensor lead off and use a regular 6pt socket. Then heat it up a bit.
  5. 062
    062 Road Train Member
    6,344
    34,002
    Oct 20, 2013
    You’re going to need some heat. If you can get it in a regen it would help. If not you can use a map gas torch.
    Sometimes you can tighten it to break it free.
    Rideandrepair and gekko1323 Thank this.
  6. gekko1323
    1,668
    2,785
    Jul 14, 2018
    Henderson, NV
    Do I heat pipe? I don't want to damage the sensor.
    Rideandrepair Thanks this.
  7. 062
    6,344
    34,002
    Oct 20, 2013
    Heat around the sensor,not the sensor itself.
    Goodysnap, Rideandrepair and gekko1323 Thank this.
  8. Spyro2112
    Spyro2112 Medium Load Member
    626
    436
    Mar 17, 2018
    P b blaster and acetone
  9. Judge
    92,738
  10. LoneRanger
    LoneRanger Road Train Member
    3,695
    9,606
    Jun 3, 2018
    I use kroil for nuts and bolts that don’t want to move.
  11. Siinman
    Siinman Road Train Member
    5,535
    14,239
    Mar 5, 2017
    Kansas City, MO.
    Nuts Off works really well for hard stuck nuts. I used to use that stuff out in the oilfield and it worked like no other.
    gekko1323 and Rideandrepair Thank this.
