Removing concrete (?) off truck.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by blairandgretchen, Nov 15, 2024.
  1. blairandgretchen
    14,031
    77,497
    Dec 9, 2011
    South west Missouri
    It looks like paint, or sprayed plaster, but it has a consistency/feel of concrete.
    Went to the truck wash - high pressure water didn't touch it, nor did their 'acid'.
    I drove through some tight construction on bridges that were being repaired on I-79 in WV , which is my only guess as to where I picked it up.
    The stacks are chrome, and the side steps are aluminum. There is a little on the paint, and some on the stainless hood drop panel.
    If ANYONE has ANY suggestion on what might be used to dissolve or remove, I'm all ears.
    I thought about asking a cement plant for ideas, they surely run into this. I thought about muriatic acid.
    This is why we can't have nice things. :(
    cke, Feedman, Ruthless and 4 others Thank this.
  3. Opus
    134,388
    you're screwed
  4. blairandgretchen
    14,031
    77,497
    Dec 9, 2011
    South west Missouri
    Gee thanks Mr. Optimism !
    Note that it has that 'orange peel' look , and the splatter seems to me like it's paint - but it's gritty like cement. Weird.
  5. Oxbow
    Oxbow Road Train Member
    13,921
    145,174
    Nov 24, 2015
    You didn't happen to run up newly newly painted lines by chance? It would have reflective (glitter) in it. That doesn't help with removal other than guessing what you are working with.
  6. Oxbow
    13,921
    145,174
    Nov 24, 2015
    Hauling wide you may have needed to run on or over the white line is what triggered my guess.
    cke, Feedman, High Stepper and 3 others Thank this.
  7. blairandgretchen
    14,031
    77,497
    Dec 9, 2011
    South west Missouri
    I thought about that - but no, doesn’t have any reflective properties like road paint.
    The applied ‘look’ resembles paint or plaster. But rock hard.
    I wondered if they apply a sealer/paint/resin to finish concrete on bridge decks. It’s white as snow.
  8. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    Maybe sandblast the steps, spray paint over the inner wheel well with bed liner or something that might hold up better than normal paint. Sand blasting aluminum use the proper medium and lower pressure. It looks almost like a white spray on bed liner for pickup trucks.
  9. blairandgretchen
    14,031
    77,497
    Dec 9, 2011
    South west Missouri
    Yes - that's it, the consistency of rhino liner.
    I thought I could sand it off the aluminum step, and have a polish guy sand and buff.
    But the chrome stacks and stainless - that's going to look pretty bad.
    cke, Isafarmboy, Feedman and 3 others Thank this.
  10. Oxbow
    13,921
    145,174
    Nov 24, 2015
    And your exhaust isn't even a year old yet is it?
  11. Cat sdp
    Cat sdp . .
    21,343
    76,549
    Apr 8, 2012
    Orion's Belt
    We used muriatic acid when I was working at a redimix plant. It will only take a haze off . It won’t touch thicker lumps or globs. And don’t use it straight water it down.
    You are basically screwed if it is concrete. I’m surprised that construction zone must of F’d up lots of cars if that’s what happened. I’d file against their bond and paint /replace the effected parts.
    cke, ElmerFudpucker, Feedman and 3 others Thank this.
