Removing stuck bolts for mudflap
Discussion in 'Experienced Truckers' Advice' started by JC1971, Oct 27, 2024.
  1. JC1971
    JC1971 Road Train Member
    2,688
    9,832
    Jul 29, 2013
    Southwestern U.S.
    What do you use? Do you carry a cordless disc grinder with you? Bolt cutters wouldn't work or they weren't big enough.
  3. blairandgretchen
    14,141
    78,231
    Dec 9, 2011
    South west Missouri
    Unfortunately, yes. You can soak them in PB blaster and bust knuckles all day long with wrenches - or cut em off.
    Best practice - use some anti seize on your nuts and bolts , use stainless, and it might - just might , be easier the next time.
  4. ElmerFudpucker
    7,744
    85,573
    May 17, 2024
    1/2” cordless impact they will come loose or break. Either way is fine.
  5. Arctic_fox
    4,808
    27,516
    Sep 16, 2016
    Yup, i actully carry a half inch air impact and have a fitting on the back of my airtank for it which is another option. Its better then a cordless for removing lugnuts if i gotta swap a tire for whatever reason but.more of a pain in the ### to use.
  6. TripleSix
    134,839
    Two box wrenches. Either they will come apart or break.
  7. ElmerFudpucker
    7,744
    85,573
    May 17, 2024
    I carry a 1” cordless impact for wheels. It’s even my go to at home now.
  8. abyliks
    abyliks Road Train Member
    4,306
    10,310
    May 2, 2010
    ludlow MA
    1/2 ratchet and doubles up wrenches would probably work but a impact would be easier, I have a cut off wheel too but don’t think
    I would need that for mud flaps
  9. Arctic_fox
    4,808
    27,516
    Sep 16, 2016
    I tried one of the 1 inch cordless before, not a bad tool, but because i do scrap a lot its not unusual for me to need to change or patch tires several times a month. That and he batterys didnt hold up if i needed to do more then 1 or 2 wheels to justify the space for it and extra battetys. I usually keep it in my pickup now since the half inch air impact works better for my use case.
    Thought about keeping my 1 inch air impact in my truck but even with the oversized tanks i can only zip 1 or 2 lugs off at a time with the big one before i run out. The half inch is just flat out easier to use most of the time and more generally useful. Also doesnt eat up near as much space.
    Rideandrepair and 88 Alpha Thank this.
  10. ElmerFudpucker
    7,744
    85,573
    May 17, 2024
    Which one did you buy? I can easily take 4 loose and back on before I need to swap the batteries out.
    Rideandrepair Thanks this.
  11. Arctic_fox
    4,808
    27,516
    Sep 16, 2016
    One of the milwaukees, its a decent tool but i could only zip off 1 or 2 tires before the battery got too weak to do anymore. Thought it was a battery issue but even with the bigger ones it lost steam after 2 changes. Part of may be that since im a rock truck that dirt gets caked into and onto everything and tends to bind them on pretty good. Usually takes a solid 30 to 40 seconds per lug to get them to break loose with the battery impact.
