Reverse lights not working
Discussion in 'Freightliner Forum' started by JohnnyC, Feb 21, 2019.
  1. JohnnyC
    JohnnyC Light Load Member
    173
    65
    Feb 17, 2009
    virginia beach, virginia
    Good morning
    2006 Century 14L Detroit 10 speed.
    My reverse lights do not turn on when I’m in reverse. Ive checked the obvious. Lights themselves, fuse/breaker. Any hint what to check next?
    Thanks for your help.
    John
  3. PermanentTourist
    PermanentTourist Heavy Load Member
    749
    881
    Nov 9, 2016
    48 states + Canada
    I think the transmission has a reverse switch that can go bad. Check for that. Here's a needlessly long youtube video about changing that switch.
  4. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    Had it happen on my old International. Just ran a wire to a switch on the dash. Never had a DOT officer ask to see it on. But had the ability nonetheless.
  5. JohnnyC
    173
    65
    Feb 17, 2009
    That has crossed my mind
  6. supersnackbar
    20,099
    52,627
    Aug 19, 2007
    Your Town, USA
    I replaced one on an old 9 speed many years ago. It was on the top of the trans, just had to take the shifter boot off the floor.
  7. JohnnyC
    173
    65
    Feb 17, 2009
    I’ll look there first,
    Thanks
  8. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    Reverse switch has 2 wires. (1) goes to rear light bulb (2) 12 v+ that shares power with air dryer heater fuse. If fuse is blown, usually signifies that air dryer heater element is bad. Unplug air dryer heater and replace fuse if I was correct.
  9. JohnnyC
    173
    65
    Feb 17, 2009
    What is the fuse labeled?
  10. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    "air dryer" 15 amp fuse. Bottom right of fuse panel. 3rd from right. (edit) had brain fart in last post. (1) wire goes to rear light bulb. not ground! (2) other wire is 12v+ from fused circuit.
  11. JohnnyC
    173
    65
    Feb 17, 2009
