SB3 Max keeps Blowing Fuse 21/8F Circuit
Discussion in 'Refrigerated Trucking Forum' started by SpeedyGonzalez, Jun 5, 2020.
  1. SpeedyGonzalez
    SpeedyGonzalez Light Load Member
    123
    59
    Dec 28, 2017
    Hi all,
    This has been an ongoing issue for the past week. I've pulled every relay off the board and tested it and followed the board schematics trying to figure out what the issue is. If I pull the run relay out all is well except for the error code, but if I put it back in and flip the switch it will instantly blow the fuse. I've tried different relays, cleaning the socket, making sure there's nothing back there, but the problem still persists. Any ideas on where to look for this magic short?
  3. reeferwrencher
    reeferwrencher Medium Load Member
    620
    1,584
    Aug 4, 2018
    Check the wires from the head pressure switch on the compressor manifold aren't rubbed through. Try disconnecting fuel solenoid and see if it still blows.
  4. SpeedyGonzalez
    123
    59
    Dec 28, 2017
    The driver got to a TK dealer, hopefully they come up with something as easy to fix as the above and don't charge an arm and a leg.
  5. SpeedyGonzalez
    123
    59
    Dec 28, 2017
    Well, got it up and running today. I think the relay board has a blown trace, the run relay is always on, and when I jumped the start relay it started right up but still has the code 35, it pops back up instantly after clearing. We're going to give the dealer another shot at it with it running and see what they say.
  6. reeferwrencher
    620
    1,584
    Aug 4, 2018
    Is it still blowing the fuse when you turn it on?
  7. SpeedyGonzalez
    123
    59
    Dec 28, 2017
    Not anymore, the code 35 still persists and I still have to jump the start relay to start the engine and the high speed relay. While probing, I found that the RRP wire has 12V when the interconnect connector is disconnected, but when i plug it in i get 4v, im not sure if RRP is supposed to pulled to ground and the 4V is being caused by a floating ground somewhere?
    The dealer tech cut RRP and ran the connector side to 12V hot and that made the code 35 dissappear but the run relay never energized.
  8. reeferwrencher
    620
    1,584
    Aug 4, 2018
    Usually when you have 12 v and lose power when you put a load on it you have a bad connection. Sounds like a mess man good luck.
  9. SpeedyGonzalez
    123
    59
    Dec 28, 2017
    It is one hell of a mess. Waiting on the local dealer to open and the driver to get back from delivering the load so I can tear into it. Roadside diagnostics with a load slowly creeping up in temp is not fun. I'm suspecting there might be a broken solder joint on the board. The wiring checked out but there was some corrosion in some of the connectors so I'll be filing contacts and greasing the connectors to prevent that moving forward.
  10. reeferwrencher
    620
    1,584
    Aug 4, 2018
    Yeah that's the sorta thing that made me grateful when thermo king came out with the sb 210/310
