Scale discrepancies.
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by MACK E-6, May 29, 2025.
  1. MACK E-6
    50,750
    246,355
    How often, if ever, are potential scale discrepancies an issue in this line of work?
    I’m sure it’s had to happen at least at some point where a quarry scale would show you legal and the state scale didn’t, or dialing them up a little so they can charge the customer for more material than they actually got.
  3. Dennixx
    Dennixx Road Train Member
    4,636
    15,091
    Feb 13, 2010
    twin cities
    Ever heard of a butchers thumb?
    I'd assume a scale was certified at some recent point but how would a customer know they are short 500lbs.
    Ours are done by the state annually.
    Different freight but our meters are proven annually too.
  4. Trashtrucker1707
    Trashtrucker1707 Road Train Member
    1,832
    5,450
    Dec 30, 2017
    I’ve been ticketed twice over the years, to the tune of a whopping $30, both times in Florida, outbound with a load of glass and inbound with a load of marble rock. A few weeks back I loaded zorba in Pensacola, scaled out around 79,500 I could tell by my tare weight their scales were off, got to Anniston and scaled in heavy around 77 and change, most of my work is tonnage rate so accurate weights are a plus, for the most part we always get it right or close, but there are those times when shippers scales are wonky.
  5. Jabuol
    Jabuol Light Load Member
    72
    302
    May 17, 2025
    Emerald Triangle
    Most of the places we weigh are within 100 lbs of each other. The state certifies them once a year and the county Weights and Measures Dept. does the same.
  6. motocross25
    motocross25 Road Train Member
    3,922
    12,112
    Sep 23, 2010
    Overland Park, KS
    I had this problem last week. The salt mine loads on a scale and has you pull up, back up, and do all sorts of dumb ####, and guys dump the clutch then slam on the brakes. So you know that suckers out of calibration. I loaded Colorado legal at 85,000. 452 miles later I hop on the scale at the dairy and I’m 87,880. :mad: Like @Trashtrucker1707 I’m paid by the ton so I don’t care, but if I would have gotten popped with some portable scales, the DOT man might’ve.
  7. wulfman75
    wulfman75 Road Train Member
    2,593
    3,963
    Jul 15, 2010
    Athens, GA
    I always find a cat scale even if the customer has one. Cat will back you up. Customer wont.
  8. hope not dumb twucker
    6,369
    55,540
    Aug 23, 2022
    This right here.
    Flat Earth Trucker and wulfman75 Thank this.
  9. Judge
    95,868
    Sucks in hopper work where you’re paid by ton.
    You’ll show loading 50000, unloading 49300, trailers empty. Their scale will be off, and over 500lb difference they’ll want photos to prove your empty.
    Then pay you on the lightest weight if they can.
  10. tscottme
    tscottme Road Train Member
    I found the same CAT scale was at least 100 pounds off when weighing the same truck and trailer. The only difference was 1 trip around the parking lot. My tanker job had us getting loaded while sitting on a customer scale. It might be 20 pounds different from 2 different times weighing the same truck trailer, product just minutes apart. The customer scale was certified maybe every month or 3 months at the most. A dedicated truck from the scale company showed up and put specific lead weights on the scale and recorded the display amount.
  11. Someguywithquestions
    Someguywithquestions Medium Load Member
    407
    675
    Jan 10, 2021
    Solid waste can be hit or miss. Scrap yards are always scamming, don't know how they don't get shut down. I've hauled pup trailers to be scrapped that weighed 2600lbs.
    Every other place I've been to hits with 200 lbs and have the state coming out and testing or being calibrated. Here in WA I'd often get loaded up to 105,300 and never more. Limit is 105,500. Almost all scales were accurate to within 60-80lbs of each other if they worked.
