Select trucks bad news
Discussion in 'Lease Purchase Trucking Forum' started by Dts dan, Sep 16, 2016.
  1. Dts dan
    Dts dan Bobtail Member
    9
    5
    Sep 15, 2016
    I bought a 2011 peterbilt with a cummins from select trucks Cleveland and took it to my local cummins dealer for preventative maintenance and found out the motor was bad it had 2 bad cams egr cooler leaking the Turbo was starting to leak oil internally and they found the main bearings to be bad from the cams going bad then I called the dealer and corporate select trucks they both told me it was my problem now what a horrible experience avoid select trucks at all costs
  3. KriegHund
    KriegHund Medium Load Member
    380
    473
    Nov 5, 2015
    On a hill south of heaven
    Should have had it inspected first.
    Dryver and jbatmick Thank this.
  4. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    Welcome op!! I see you're new here and by your post also new in trucking! Well, there's nothing you can do now, maybe sell it at a loss or try to fix it up. But I suggest next time, get it inspected and get an oil sample.
    This is a big purchase, you don't buy a house without going inside to take a look right!? Then u shouldnt buy a truck without taking a look
  5. Dts dan
    9
    5
    Sep 15, 2016
    It was all internal damage unable to see or detect until they pulled the valve cover to run the rack on it
  6. Chinatown
    Chinatown Road Train Member
    77,789
    184,708
    Aug 28, 2011
    Henderson, NV & Orient
    Are you in a situation where you can trade it off?
  7. SHOJim
    SHOJim Road Train Member
    3,399
    17,211
    Apr 19, 2011
    Columbus, Ohio
  8. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    An oil sample would have shown it. 20 bucks.
    Pete jockey and blairandgretchen Thank this.
  9. Chinatown
    77,789
    184,708
    Aug 28, 2011
    Trade it in; tell whoever the truck isn't spec'd right for you. You need a lighter weight or a mid roof or different transmission or whatever you can come up with.
    Bakerman Thanks this.
  10. Highrisk21
    Highrisk21 Light Load Member
    132
    63
    Aug 22, 2016
    Yeah do that so the next owner operator can buy if and get fked and lose all his money trying to fix it. You should be ashamed in not even thinking about the next guy that buys that truck possibly fulfilling a dream of owning a truck to provide for his family.
    This guy either needs to fix it or disclose the issues and sell it at a loss. That's trucking you will make and lose money unfortunately it happened sooner than later to this guy before he could get a nice cushion of money built up. Good luck to you and do the right thing whatever that may be for you.
  11. Chinatown
    77,789
    184,708
    Aug 28, 2011
    The next guy should have it properly inspected before signing the papers and let the truck dealership take the hit.
    SoCalRed, Ssand Man, jeff18 and 5 others Thank this.
