Series 60 Detroit DDEC3
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by RUSTBOXF700, Mar 23, 2023.
  1. RUSTBOXF700
    RUSTBOXF700 Bobtail Member
    12
    19
    Mar 23, 2023
    I am having an issue with this truck, when the truck is idling it runs fine, but when you release the park brake it runs erratic and rough? And if you drive it, it will intermittently run fine. The truck is a KW T800. Any recommendations on were to start?
    blairandgretchen Thanks this.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Flash codes then a scan tool.
    Bean Jr. and Rideandrepair Thank this.
  4. DDguy
    DDguy Light Load Member
    157
    101
    Apr 21, 2020
    Ont. Canada
    When did this problem start ? or is there any more info to point us in the right direction ?
    Rideandrepair Thanks this.
  5. RUSTBOXF700
    12
    19
    Mar 23, 2023
    It started a little bit after the injectors were done and the overhead was adjusted.
  6. DDguy
    157
    101
    Apr 21, 2020
    Ont. Canada
    You may have a fuel pressure issue Maybe injector Orings or even dirt got into the fuel Galley ?
  7. RUSTBOXF700
    12
    19
    Mar 23, 2023
    Only got blink codes so far, waiting on new scan tool to arrive. The stop engine light blinks 2 then 5. All others are inactive on the check engine light links.
    DDguy and Rideandrepair Thank this.
  8. RUSTBOXF700
    12
    19
    Mar 23, 2023
    Would the fuel pressure issue cause the issue when the park brakes are released? It will idle and run fine until you push the release button in for the park brakes and then it will run poorly and missfire, set the parking brakes and the engine will immediately run fine again? I have never seen this condition before but I also have only worked on 2 other detroits before this one and they were newer
  9. DDguy
    157
    101
    Apr 21, 2020
    Ont. Canada
    Okay this Means i need to look at your program then
  10. Rideandrepair
    17,572
    56,924
    Aug 8, 2015
    My yellow CEL doesn’t work either. Without the stored codes, it’s hard to tell. I was able to catch a problem while it was happening, and got the active codes. Actually the code was intermittently active, for low coolant. I had to determine if it was the sensor, or the harness. Got lucky and caught it while active. Maybe try to get the codes while it’s running rough. If there’s any active codes, they should flash. I’m sure you know that code 25 means no codes.
    DDguy and BoxCarKidd Thank this.
  11. blairandgretchen
    13,966
    76,806
    Dec 9, 2011
    South west Missouri
    The only thing I can think of is the cruise control circuit - clutch switch and brake switch need to be off for cruise to work, and I would guess the sensor on the park brake circuit ties into it too - and there's been a splicing of wires or rubbing of wires that feed to the ECM that's messing it up.
    Is it your truck? Has there been any wiring work done? Inspect the harness pretty closely, or maybe try a test ECM if you can source one.
    Not a mechanic, but that's all that comes to mind.
    Oxbow, JoeyJunk, DDguy and 1 other person Thank this.
