Shifting gears question
Discussion in 'Questions From New Drivers' started by dennisroc, Feb 19, 2014.
  1. dennisroc
    dennisroc Road Train Member
    1,753
    1,257
    Oct 9, 2013
    Anjung-Ri, South Korea
    Some people double clutch and some float the gears. I have 2 questions here.
    1. What would happen if you shifted a tractor like you would a normal standard transmission.
    2. What do most of you drivers on this site do, double clutch or float.
    Thanks !
  3. bp88
    bp88 Light Load Member
    149
    48
    Apr 20, 2013
    Orange County, CA
    1. Wears out the clutch brake and most likely grind every time. You need to give it a little time for the RPM's to drop a bit for the next higher gear. Ever notice that the higher gears like it when you upshift a bit slower?
    2. I double-clutch 99% of the time. It keeps me busy. :p
    dennisroc, gpsman and Skydivedavec Thank this.
  4. TruckDuo
    TruckDuo Road Train Member
    6,394
    9,373
    Oct 21, 2012
    Chicago, IL
    Mostly double clutch otherwise I'll use the clutch to get it out of gear then float it into gear.
    dennisroc Thanks this.
  5. kaygirl
    kaygirl Light Load Member
    147
    86
    Oct 14, 2013
    Western Australia
    before i started my new job, i did a lesson with a driving instructor, just to refamiliarizse myself with gear shifting (it had been a while and i didn't want to look like a complete loser). the only time i used the clutch with him was to take off and stop. floating all the way up and down. turns out the trucks at my new company are either autos or synchronised manuals.
  6. Reverend Falstaff
    Reverend Falstaff Light Load Member
    203
    176
    Sep 15, 2009
    I float 'em. Haven't double clutched since my road test for current company 10 years ago. Well maybe a couple times since to see if I could remember the touch.
  7. paul 1052
    paul 1052 Heavy Load Member
    899
    346
    Oct 9, 2010
    Sand Springs, Ok.
    The last time I double clutched was over 25 years ago on the road test for my license. I've put about 9.5 K on this truck w/o a doubleclutch.
    Learn to float.
    Skydivedavec and dennisroc Thank this.
  8. ethos
    ethos Trucker Forum STAFF Staff Member
    4,346
    15,246
    Mar 3, 2013
    Fort Worth
    Double clutch when I have a student but float when I'm alone. Floating to me is the better way to shift, easier on the truck and me.
  9. madman118
    madman118 Light Load Member
    244
    148
    Mar 13, 2012
    Sacramento, CA
    I float the gears.
  10. jsprocket
    jsprocket Heavy Load Member
    830
    262
    Nov 4, 2013
    Columbus, GA
    Float. Just easier
  11. fencitup
    fencitup Light Load Member
    225
    113
    Jan 12, 2014
    Bronx, NY
    I get its easier on you... but how is it easier on the the truck?
