Shifting Gears
Discussion in 'Questions From New Drivers' started by DJ Hughes, Jun 24, 2015.
  1. DJ Hughes
    DJ Hughes Light Load Member
    139
    46
    Jun 13, 2015
    Tennessee
    Im happy to say Im getting better at backing on the course at my school. Now Im hitting the road with my instructor for some drive time. My first trip out was ok I hold my lane good and very cautious while driving. Im good at keeping my trailer on my side and not tearing down any road signs while turning and watching my mirrors and knowing whats going on around me but Im having trouble shifting gears, I do good on upshift but down shifting is being a pain. We are training on 10speeds. I will get it but any advice? By the way they want us to double clutch. I take my skills test on july7 in Louisville TN.
    Wild Murphy Thanks this.
  3. texasbbqbest
    texasbbqbest Road Train Member
    1,088
    1,962
    Dec 9, 2014
    Minneapolis, MN
    Can't say much for double clutching as I never learned (and didn't need it for my road test at my employer) but in terms of shifting gears - Try to relax a little. Don't slam it in to gear. Every shift should be just one fluid motion. It you do that, the gears will fall into place unlike if you force it. Don't forget to raise/lower the splitter immediately after you hit 5th (going up) or 6th (going down).
    As for downshifting specifically - THIS IS WHAT I DO.
    On the interstate start slowing down GRADUALLY long before you come to your exit. That way you have time to downshift through all/most of the gears. It's good practice this way. This also works for stop signs (except you will come to a complete stop instead of continuing on).
    Coming up on red lights, start slowing down a ways before the light like above, but only go down a gear or two (enough to where you are going at a speed that if the light turned green you wouldn't have to stop at all and you could just grab gears again).
    You'll get it buddy!
    I am in orientation at Prime, Inc right now and something that has helped me tremendously is the practice I've had using their simulators. That way if you screw up you can stop on the interstate, in the middle of an accident scene (yeah, I did that, shuddup!*) and its fine because it's not in real life.
    *I learned on an 8 speed and Prime's are 10's. I forgot the gear pattern...
    Hope this helps and doesn't confuse the hell out of you!
    DJ Hughes Thanks this.
  4. Ordy19
    Ordy19 Medium Load Member
    454
    416
    Aug 19, 2014
    Clutch in, pull it out of gear, rev to 12-1500 rpms. press clutch, and slide it in as they begin to drop again. Be gentle, think of it as a lady, if you have to force it in, something isn't right.
    15 mph = 1+5 = 6th gear
    25 mph = 2+5 = 7th gear
    35 mph = 3+5 = 8th gear
    45 mph = 4+5 = 9th gear.
    I am not trying to insult your intelligence with this basic math just trying to make it make sense and what my instructor taught us.
    when you fall below 10000 rpms or you start to lug, that's a pretty good sign that it is time to down shift. That is the crash course they taught me in school. I just took my road test Monday and did it that way and throughout the entire course and did fine and passed.
    Something else, say you are cruising at 45 MPH and you are in 9th gear and you notice that your truck is at let's say 13000 rpms. Well that would be the sweet spot for it to float in when you are going 45 MPH's, but they tell you between 12-15000 because that usually works too.
    DJ Hughes and D33RHUNT3R Thank this.
  5. EndHatred
    EndHatred Medium Load Member
    513
    381
    Jun 9, 2015
    Good tips here from everyone, unless you're learning on a Super 10, are you? That's where you must move the lever every gear up or down. In any case, stop worrying is my best advice. A trick I used when first starting was to practice in my head just before I went to sleep at night.
  6. CaliforniaJellyroll
    CaliforniaJellyroll Light Load Member
    157
    91
    Jun 15, 2015
    texasbbqbest Thanks this.
  7. marineman227
    marineman227 Dock Waterer
    600
    796
    Jan 26, 2008
    Neenah, WI
    In addition to what everyone else said keep your palm off the shifter. Use your finger tips only. You can feel the gears meshing better that way and won't be slamming it into gear jarring the truck.
    You can even trick your tester a bit if you're having trouble getting your RPMs right you can gently lean the shifter against the gear you're trying to get and feel it grind, as the grind gets slower you're getting closer then just drop it in. With a real light touch you won't actually hear it grind you will just feel it in your fingertips so they won't dock you points for grinding.
    unholy7 and texasbbqbest Thank this.
  8. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Thats also how you start to learn floating..
    S M D Thanks this.
  9. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
    Once you go I shift, you don't want to go back.
  10. blairandgretchen
    13,964
    76,789
    Dec 9, 2011
    South west Missouri
    Only push the clutch in an inch or two - not all the way to the floor where the clutch brake is.
    You may either be trying to shift too fast - or too slow.
    I had to relearn a 13 speed - it's taken me almost 3 months to get used to it after a 10 speed - it wants shifted QUICK, not gentle and slow like the 10.
    You'll get it. Just don't hit nuffin.
  11. hunted
    hunted Medium Load Member
    Oh my GOD!!!!!!!!!! 2 + 7 = 7?????????? Your little formula is off great advice there nice job
    Ordy19 Thanks this.
