Shifting sweet spot
Discussion in 'Questions From New Drivers' started by Mr. EastCoast, Mar 20, 2021.
  1. Mr. EastCoast
    Mr. EastCoast Light Load Member
    80
    65
    Aug 26, 2020
    I know every truck is different but what’s the sweet spot for shifting lower gears and high gears.
    Farmerbob1 Thanks this.
  3. GreenPete359
    GreenPete359 Road Train Member
    2,256
    5,433
    Oct 21, 2017
    Driving my recliner
  4. Arctic_fox
    4,521
    25,591
    Sep 16, 2016
    Look up your engine and transmission. Most have a chart someplace that shows peak torque at X rpm. That gives you a starting point, once you know that you can play around with various shifts in that range. Otherwise its all trial and error as even 6 trucks with the exact same setup will shift at 6 diffrent places.
  5. TripleSix
    133,465
    Yep. Some engines rev higher. Some transmissions have thumb splitters. Some turbos have more lag.
    And bigger HP engines will grenade drivetrains much easier so you progressive shift them. Well, I do.
  6. bad-luck
    bad-luck Road Train Member
    3,439
    6,333
    Nov 16, 2013
    Baltimore, Maryland
    You answerd your own question in your first sentence....
  7. Frank Speak
    Frank Speak Road Train Member
    4,583
    14,117
    May 3, 2016
    Listen to the engine. She’ll tell you her dirty, dark shifting secrets.
    *lights after shifting smoke*
    AModelCat, Farmerbob1 and GreenPete359 Thank this.
  8. RockinChair
    RockinChair Road Train Member
    5,389
    14,461
    Feb 19, 2012
    Lubbock, TX & thereabouts
    If you're heavy, shift at a high enough RPM that the engine will still be above peak torque when you start the next gear.
    Rideandrepair and Farmerbob1 Thank this.
  9. D.Tibbitt
    157,243
    What does progessive shifting mean?
  10. Frank Speak
    4,583
    14,117
    May 3, 2016
    Progressively increasing the rpm for each gear.
    Example:
    1st to 2nd at 1000, 2nd to 3rd at 1100..... 9th to 10th at 1400.
    Rideandrepair, TripleSix and D.Tibbitt Thank this.
  11. Dave_in_AZ
    425,724
    1400 for your baseline in low range. You might adjust that 50 rpm either way.
    1450 to 1500 in high range as a baseline.
