Should a unit defrost with on 35 Continuous!
Discussion in 'Refrigerated Trucking Forum' started by xlsdraw, Aug 17, 2018.
  1. xlsdraw
    xlsdraw Road Train Member
    4,240
    9,019
    Nov 17, 2010
    Lake Alfred, Florida
    Should a unit even do a defrost when set on 35* Continuous? After defrost, it was at 44* and Cut off. Switched it off and back on. Went green and ran for a couple minutes but wouldn't cool, then it shut down again. Headed to Carrier now. Primary question is should even a proper working unit even need to defrost with a 35* setting?
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Most units defrost every 6-8 hours regardless [on a schedule] whether it thinks it needs to or not. This timed defrost schedule is set by admin.
    But it sounds like yours has some other issues going on.
    magoo68, turtletk and xlsdraw Thank this.
  4. reeferwrencher
    reeferwrencher Medium Load Member
    613
    1,577
    Aug 4, 2018
    Yes because the evaporator(cooling) coil is much colder than 35 and will become blocked with ice if it isn't defrosted.
    slow.rider, turtletk, DTP and 3 others Thank this.
  5. GreenPete359
    GreenPete359 Road Train Member
    2,260
    5,441
    Oct 21, 2017
    Driving my recliner
    Yes. When hauling flowers we set them at 36 and they defrosted all the time in the summer
    slow.rider and xlsdraw Thank this.
  6. ebill45
    ebill45 Light Load Member
    167
    105
    Oct 11, 2011
    dalton ga
    Yes in this heat of course. If the temp outside is higher than in the box it needs to be doing a defrost cycle
