Should I be on duty or off duty
Discussion in 'Questions From New Drivers' started by Mohtrucker, Nov 10, 2019.
  1. Mohtrucker
    Mohtrucker Light Load Member
    135
    188
    Oct 20, 2019
    I'm in a breakdown situation on the shoulder of the interstate. It seems as of this will be awhile & wanted to know If I log on duty the entire time or off duty
    D.Tibbitt Thanks this.
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    depends. if you need a 30min break or the 2 and 8 split
    Mohtrucker and D.Tibbitt Thank this.
  4. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,794
    Jan 17, 2017
    On duty while you set up road markers. On duty if you are trying to fix it yourself. Off duty if you are sitting in the cab waiting for a tow or service.
    If that's not how it works, then I also need to learn something!
    Wespipes, PE_T, x1Heavy and 4 others Thank this.
  5. D.Tibbitt
    157,334
    Yes you are required to be on duty.....you are waiting for a road side repair to come, u are not relived from your duties as a truck driver... It is ur choice to log watever u want....if u are running short on ur 70 , it could be a tough choice to make. I killed over 6 hours of my clock waiting for roadside to come change a blown tire and my 70 was short and ended up having to get load rescheduled........part of the game sometimes.... Like i said ur choice to do as u wish , but the dot man is gonna wanna see u logged on duty for roadside
    MrEd, 12 ga, tscottme and 12 others Thank this.
  6. Opus
    132,805
    This is correct. Unless your carrier has relieved you from all duties and responsibilities, you are on duty.
    12 ga, 88 Alpha, Farmerbob1 and 9 others Thank this.
  7. sherlock510
    sherlock510 Road Train Member
    1,066
    1,058
    Jul 26, 2011
    Intercontinental.
    Save time and log off duty. Only your company will know you were on the shoulder for roadside assistance.
    I mean we all know the right way to do it.. Who is always 100% as a company driver?
    Oh ok..
    PE_T, starmac, Farmerbob1 and 5 others Thank this.
  8. kemosabi49
    10,994
    47,990
    Jan 13, 2013
    SW Arkansas
    From The regs. Part 395.2. Note Number 6.
    On duty time means all time from the time a driver begins to work or is required to be in readiness to work until the time the driver is relieved from work and all responsibility for performing work. On duty time shall include:
    (1) All time at a plant, terminal, facility, or other property of a motor carrier or shipper, or on any public property, waiting to be dispatched, unless the driver has been relieved from duty by the motor carrier;
    (2) All time inspecting, servicing, or conditioning any commercial motor vehicle at any time;
    (3) All driving time as defined in the term driving time;
    (4) All time, other than driving time, in or upon any commercial motor vehicle except time spent resting in a sleeper berth;
    (5) All time loading or unloading a commercial motor vehicle, supervising, or assisting in the loading or unloading, attending a commercial motor vehicle being loaded or unloaded, remaining in readiness to operate the commercial motor vehicle, or in giving or receiving receipts for shipments loaded or unloaded;
    (6) All time repairing, obtaining assistance, or remaining in attendance upon a disabled commercial motor vehicle;
    (7) All time spent providing a breath sample or urine specimen, including travel time to and from the collection site, in order to comply with the random, reasonable suspicion, post-accident, or follow-up testing required by part 382 of this subchapter when directed by a motor carrier;
    (8) Performing any other work in the capacity, employ, or service of a motor carrier; and
    (9) Performing any compensated work for a person who is not a motor carrier.
    12 ga, PE_T, brian991219 and 11 others Thank this.
  9. D.Tibbitt
    157,334
    Are u sure about that, because the elog records ur position at all times
    Bean Jr., PE_T, truckdriver31 and 3 others Thank this.
  10. kemosabi49
    10,994
    47,990
    Jan 13, 2013
    SW Arkansas
    And when the dot show up while you're waiting on that service truck, he may want to see you on duty on your eld.
  11. sherlock510
    1,066
    1,058
    Jul 26, 2011
    Intercontinental.
    Right, so his company knows what's going on. If DOT sees off duty for 5 hours in so and so city, will they magically know he should have been on duty for roadside? Or was he taking a nap on the off ramp?
    Highway patrol maybe. When's the last time you seen DOT enforcement behind someone getting a shoulder repair? I haven't.
