Single axle and tandem pup
Discussion in 'Experienced Truckers' Advice' started by Jashon012, May 11, 2024.
  1. Jashon012
    Jashon012 Bobtail Member
    Im considering buying a set of doubles for LTL. I’m looking for some advice on whether or not it’s ok to operate with a 28’ single axle coupled with a 28’ tandem axle with liftgate. These two trailers I’m looking to buy but I want to make sure this set up is operational. Any advice would be great appreciated
  3. abyliks
    abyliks Road Train Member
    4,146
    9,787
    May 2, 2010
    ludlow MA
    Heavier trailer needs to be the lead, axles don’t matter
    wis bang, ‘Olhand, Jashon012 and 3 others Thank this.
  4. Lazer
    Lazer Road Train Member
    1,850
    2,983
    Jan 22, 2017
    Are you wanting a lift gate on both pup trailers?
    Jashon012 Thanks this.
  5. FLHT
    FLHT Road Train Member
    1,438
    2,578
    Aug 2, 2014
    Pintel hooks and Lift Gates have clearance problems
    Look at your big LTLs set up most only pull the trailer with the lift gate in the rear position.
    Some have no hook or have been taken off.
    As far as a tandem axel to pull pups . King pin settings must be far enough forward so the trailer landing gear does not get caught up in the trucks frame.
    Many can not run with mud flaps . They get ripped off
    Some hit the frame of truck before the fifth wheel even latches
    Jashon012, TripleSix and Judge Thank this.
  6. Judge
    92,756
    Exactly.
    My mudflaps, which i had to get out before hooking, to make sure i wouldn’t rip them off, were right there a finger width of dollys.
    Had to move fifth wheel and just barely could clear, one notch more and i’d have had to take off the flaps.
    Sons Hero and Jashon012 Thank this.
  7. upnorthwpg
    upnorthwpg Road Train Member
    1,830
    2,802
    Sep 23, 2011
    Like the second post said. You’re limiting yourself by always having to make sure the non tailgate pup is heavier, which probably defeats the purpose of a power gate. Why not just get a 40’ trailer with a gate?
  8. DonRobbie
    DonRobbie Road Train Member
    1,080
    2,687
    Nov 26, 2005
    Midwest
    I have only dealt with doubles in the foodservice context. I have seen tandem and single axle pups mixed in some foodservice fleets and they didn’t seem to have any exceptional issues.
    There are two things that come to mind. First, depending on what you’re hauling the tandem pup with the gate might be more weight than you can afford. Doubles are heavy. Granted they were reefers with ramps, side doors, and freezer stairs, but one of our sets full of fuel with a modern emissions tractor was nearly 51,000 lbs. Generally the only axle weight I had any concern with was the drive axle when we were running single screws. Gross weight on the other hand was a constant battle. I’m sure dry van pups are much lighter but they’re still going to run heavier than a long single trailer. So if weight is at all a concern I’d check what the whole combination scales out to and be sure that works for your application.
    Second, while you’re scaling them out, getting individual weights so you can ‘handicap’ the trailer weights each day and not have to guess which one is heavier if the single axle pup has a heavier load one day. You can get away with the kite (back trailer) being 1-2k heavier. How they are loaded will make a difference as well, if the weight is spread evenly along the length of the trailers it will handle better and be more forgiving.
  9. Jashon012
    No just the rear trailer. I want the single axle to be lead trailer with no lift gate
  10. Jashon012
    That’s true . I want the tandem lift gate to be the rear trailer so no issues there with the truck . I was really concerned with different axles being an issue honestly
  11. FLHT
    1,438
    2,578
    Aug 2, 2014
    Their were multiple trailers with lift gates at almost every YRC terminal.
    Check the auctions at Richey Bros.
    Their were also convertor gears all going cheap.
    Make sure what ever you do that the snubber works ..
