sleeper requirements
Discussion in 'Questions From New Drivers' started by atmeyer, Jul 6, 2019.
  1. atmeyer
    atmeyer Bobtail Member
    9
    9
    Jul 6, 2019
    Hello... sorry, i am new to this. i am sure this has been addressed, but i have seen so many conflicting statements regarding it. if i am a SOLE driver, do i need to comply with the sleeper cab requirements? or can i log off and sleep in the back seat. it seams to me that the sleeper requirements are intended for multiple drivers, where one is driving and the other is sleeping. why else would they require such things as a safety harness unless the vehicle was moving? thank you for any clarification.
    studebakerman2001 Thanks this.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,142
    Mar 5, 2016
    White County, Arkansas
    IF your truck is a DAY CAB. NO Sleeper... you cannot use Tractor as a sleeper. There is none.
    IF your truck IS a sleeper truck. AND YOU are the SOLO driver OR a TEAM driver then you read:
    FMCSA summary
    Regulations Section
    Actual gospel in regulations for FMCSA for all truckers with Sleeper Trucks as of July 3 2019
    eCFR — Code of Federal Regulations
    Remember.
    You have 11 hours to drive with a 30 minute mandatory break and a 14 hour total onduty/driving logging work day in a sleeper truck. You have 70 total hours in 8 days. (A older rule allowed for 60 Hours in 7 days depending on your company) Your sleeper is your rest. Your home. Your CAB is the office. A workplace.
    Hope this helps.
    Metallica88 Thanks this.
  4. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    the BACK SEAT in not a sleeper.
    sleeper requirements have nothing to do with multiple drivers (team)
    x1Heavy Thanks this.
  5. atmeyer
    9
    9
    Jul 6, 2019
    i'm starting a hotshot buisness with a crew cab. i've heard lots of people say different things regarding sleeping in the back seat... this is specifically about using a 1 ton crew cab truck
  6. flood
    4,168
    4,047
    Dec 25, 2010
    can't log sleeper if you don't have one
    x1Heavy, 88228822 and AModelCat Thank this.
  7. Ridlingdj
    Ridlingdj Medium Load Member
    414
    562
    Dec 12, 2018
    They make a blow up mattress for the front part of the seat to make it level all the way across to your front seat put that in and curtains if you wish in the back but you wont be comfortable and I dont think dot really cares as long as you are stopping and getting adequate sleep to not be tired
  8. motocross25
    motocross25 Road Train Member
    3,873
    11,882
    Sep 23, 2010
    Overland Park, KS
    There’s stipulations and requirements to what counts as a DOT compliant sleeper berth. I dunno what they are, but I know throwing an air mattress over the back seat doesn’t count. Here’s a link to a company that’ll convert yours to be compliant.
    Woodhouse
    x1Heavy and Lepton1 Thank this.
  9. atmeyer
    9
    9
    Jul 6, 2019
    the time wouldnt be logged as sleeper, but off duty. at least that is what i have heard others commonly do
  10. x1Heavy
    34,016
    42,142
    Mar 5, 2016
    It is not a sleeper.
    YOU CAN however send that truck to a SHOP to TEAR OUT that back cab and BUILD a DOT APPROVED ONE man sleeper onto it for a number of thousands of dollars depending on your truck model.
    YOU are a CREW CAB. Take 4 people with that backseat. NOT a sleeping space that is legal, lawful or allowable under DOT trucking rules.
    Lepton1 and motocross25 Thank this.
  11. COBB2070
    COBB2070 Medium Load Member
    369
    416
    Jul 8, 2018
    SoCal...The OC
    not4hire, Lepton1 and x1Heavy Thank this.
