Sliding 5th wheel weight transfer
Discussion in 'Experienced Truckers' Advice' started by mitmaks, Nov 8, 2018.
  1. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    How much weight can you move from trailer axles if you slide your 5th wheel?
    I have truck with permanently mounted 5th wheel so just wondering how much weight you can usually move with sliding 5th wheel.
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Zero, zilch, nada, 0, none.
    NoBigHurry, kylefitzy, snowwy and 5 others Thank this.
  4. 06driver
    06driver Road Train Member
    2,436
    3,434
    May 28, 2017
    Sliding fifth wheel moves weight between the steers and the drives.
    NoBigHurry, stwik, kylefitzy and 2 others Thank this.
  5. mitmaks
    2,586
    2,102
    May 16, 2014
    Wouldn't sliding it forward towards cab move at least 200lbs from trailer axle?
  6. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Spicolli. Do you want to answer that?
    whoopNride and snowwy Thank this.
  7. 06driver
    2,436
    3,434
    May 28, 2017
    No.
    kylefitzy Thanks this.
  8. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    And who says people aren’t getting their money’s worth in CDL school and apprentice training? ... and high school physics.
    stwik, kylefitzy, ZVar and 1 other person Thank this.
  9. AModelCat
    164,728
    Moving the 5th wheel should transfer zero weight from the trailer. All you're doing is changing the point where weight transfers to the tractor (which changes the weight ratio between drives and steer). Unless you were to physically move the location of the kingpin on the trailer frame, no weight will shift from trailer to tractor.
  10. Bigrayon
    Bigrayon Road Train Member
    1,283
    646
    Aug 16, 2015
    I say a guy with a 780 move the fifth wheel on get legal on the trailer, I told him I didn't think so but he said yes on the 780 it does work, I watch him do it and yes it does work, we was at the Miller Coors in tx, we then went to the qt on I was left with my mouth closed,
  11. AModelCat
    164,728
    Basic physics disagrees.....
    NoBigHurry, stwik, 06driver and 3 others Thank this.
