slight screech!! Help me pls
Discussion in 'Freightliner Forum' started by Votto, Jun 27, 2022.
  1. Votto
    Votto Bobtail Member
    Jun 27, 2022
    good night, my truck is a dd13 and it has been 2 days since when I accelerate above 1500 rpm a slight screech is heard only when I accelerate above 1500 rpm the truck works well only that slight screech is heard…. What could it be?
  3. Chieftains
    Chieftains Medium Load Member
    362
    896
    Jul 18, 2021
    Has it been fixed permanently
  4. Flat Earth Trucker
    4,324
    16,671
    Nov 19, 2018
    A fan clutch that is going out will create a screeching sound when it first engages. Just a guess.
    @AModelCat
    Big Road Skateboard Thanks this.
  5. 501knight
    501knight Light Load Member
    61
    79
    Dec 8, 2021
    Could be either tensioner or the belts to alternator to rule out belts spray water on belts when running if noise stops then I would say its belts, if squeal still there by what you described I would say tensioner pully
