Speedometer not working
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 7seriestv, Mar 30, 2020.
  1. 7seriestv
    7seriestv Light Load Member
    230
    144
    Jan 28, 2016
    2005 freightliner century
    Eaton fuller 10 speed smartshift transmission
    Just purchase this truck, been on the road about a month now with it. Some days the speedometer meter work some days it don't. Like wise somedays the qualcom show I'm driving somedays I'm driving and it just show I'm off duty. The miles on the truck increasing and the tachometer work. So far I replace both speed sensors at the back of the transmission, wire harness from tcm to all sensors on the transmission including speed sensor, did continuity test on speed sensor harness going from the speed sensor to the ecm. What else would cause the speedometer and the qualcom to not show that I'm driving.
  3. truckdriver31
    7,001
    8,367
    Sep 18, 2013
    have you tried hitting the dash or gauge first. i got a 2nd ram and if it sits for a few days i got to hit top dash to make speedo work
  4. Dino soar
    Dino soar Road Train Member
    4,834
    27,123
    Dec 8, 2017
    Ahhh...
    The Fonzie technique!
    Now if you can snap your fingers and chicks come running...
  5. truckdriver31
    7,001
    8,367
    Sep 18, 2013
  6. 7seriestv
    230
    144
    Jan 28, 2016
    I will try that, at least if it work I have a starting point. Right now I'm out of ideas where to start searching. I was thinking the gauge bad but the qualcom doing the same thing so the problem is somewhere the two tied together
  7. truckdriver31
    7,001
    8,367
    Sep 18, 2013
    maybe speedo sensor
  8. 7seriestv
    230
    144
    Jan 28, 2016
  9. Judge
    95,668
    The most common causes of a speedometer that stopped working include are a faulty speed sensor, broken gear on the speedometer, damaged wiring, or a faulty engine control unit.
    Have had cable come loose on transmission at the speed sensor.
  10. 7seriestv
    230
    144
    Jan 28, 2016
  11. Rideandrepair
    17,629
    57,052
    Aug 8, 2015
    That explains all the cracked dashboards, Lol
