Spindle Repair
Discussion in 'Ask An Owner Operator' started by XJ01, Jul 24, 2024.
  1. XJ01
    XJ01 Bobtail Member
    Mar 10, 2016
    Pulled the hub on my trailer to work on the brakes and change the seal and found this, that look like a legit repair or someones hack job and I should just go ahead and get the spindle replaced?
    Flat Earth Trucker and NightWind Thank this.
  3. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,963
    Oct 31, 2023
    There are places that will come out to you and repair it. Try searching for Axle Doctor or something like that in your area. Some will put an entirely new piece on and others will put a sleeve on it.
  4. Judge
    95,550
    one in little rock, arkansas, axle surgeon, just had one replaced.
  5. Goodysnap
    Goodysnap Road Train Member
    3,825
    9,330
    Jul 12, 2017
    It just had the outer bearing journal done and not the whole spindle.
    Looks like a pro job to me. I say send it.
  6. ElmerFudpucker
    7,752
    85,640
    May 17, 2024
    Axle surgeon will come to you. Cost around 1600 for the last one I had done. All they do is repair. You must tear it down and put it back together. Honestly though it looks solid. Is it straight? I’m not sure if I would run it or not.
  7. Big Road Skateboard
    7,952
    46,513
    May 2, 2021
    Looks like a hack job to me. I've had Axle Surgeons do probably 50 jobs for me, and have seen a few others.
    All replaced the whole spindle. Maybe there's a way to do that reliably, but I haven't seen it offered
  8. ElmerFudpucker
    7,752
    85,640
    May 17, 2024
    I can only imagine they cut off a half spindle from a junk yard. That’s really the only way I know to get one. It’s certainly not going to be as strong as replacing the whole spindle. I can only assume it’s just butt welded.
  9. Iamoverit
    2,159
    4,963
    Oct 31, 2023
    They order them new separately and some even make them. There's a video on YT showing the process.
  10. ElmerFudpucker
    7,752
    85,640
    May 17, 2024
    A half spindle?
  11. Iamoverit
    2,159
    4,963
    Oct 31, 2023
    Sorry, I misread your post.
    ElmerFudpucker Thanks this.
