Steer tire wear
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dorde89, May 16, 2020.
  1. Truckers Report Jobs
  2. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    I've run into this from "hugging the fog line". The outside edge runs up on the edge/slope of ruts in the road and wears them out.
  3. Dorde89
    Dorde89 Bobtail Member
    40
    14
    Aug 5, 2016
    So this is normal?
  4. skellr
    8,735
    12,187
    Jul 17, 2011
    It was in my case... And If you try to stay on the right side of your lane, I can see it happening. I took it in for alignment at two different shops and it was "good".
    I'm no mechanic. I'm sure there will be more comments to come.
    Edit: I only noticed the wear on the steers tires, not the drives... it was odd.
    Dorde89 Thanks this.
  5. blairandgretchen
    13,958
    76,760
    Dec 9, 2011
    South west Missouri
  6. Dorde89
    40
    14
    Aug 5, 2016
  7. lester
    2,957
    8,086
    Jan 2, 2012
    NW, Iowa
    He's saying you probably need an alignment and he's recommending that guy
    blairandgretchen and Dorde89 Thank this.
  8. Dorde89
    40
    14
    Aug 5, 2016
    I done alignment. Thanks
    blairandgretchen Thanks this.
  9. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    How many miles on them? Both sides doing it? Just went and looked at mine. Outside (same type edge) is slightly lower, on both sides and on both tires. My tires are FS 591 Firestone. Mine have almost 45k miles. If you run your hand across and tires are nice and flat, no feathering i think your good. Think tire man called it the decoupling grove?
  10. Dorde89
    40
    14
    Aug 5, 2016
    I put michelin tire before 3k miles . Both sides both tires i have that wear . Especially when it is hot outside.
    stillwurkin and blairandgretchen Thank this.
