Strange problem. Cruise will not set with headlights on.
Discussion in 'Freightliner Forum' started by mitrucker, Aug 29, 2019.
  1. mitrucker
    mitrucker Road Train Member
    5,480
    10,286
    Dec 15, 2010
    Lapeer, MI
    2009 Cascadia DD15, 10 spd manual. Cruise control cuts out and will not set if you turn on headlamps, or wipers, or four ways. Other than that, cruise functions normally. Thoughts????
  3. RoadRooster
    RoadRooster Road Train Member
    4,121
    6,710
    May 10, 2015
    Fort Myers, Florida
    Cruise designed for day can...no night drives?
  4. wichris
    wichris Road Train Member
    4,492
    9,250
    Jan 17, 2011
    Plug in and change the parameters.
  5. CraigInReston
    CraigInReston Light Load Member
    138
    134
    Apr 6, 2017
    Take it in to the 'stealership'. They'll have to plug-in with their software to determine the problem. Otherwise you could just be throwing parts at it. Pay the extra $$$ and save yourself the headache.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Yup, dealer set parameters.
    My 2016 did that brand new.
    At first I had dealer set it to disabled, but then the cruise didn’t work at all. Then had it set to four way flasher only. That did the trick. I figured if I had the 4 ways on , I probably had more important things to worry about than cruise control.
    I forget the parameter, but had something todo with the MFC switch, cruise parameters. I have Detroit Diesel Diagnostic Link Standard edition, but you need the Professional version to access it.
    mhyn Thanks this.
  7. mitrucker
    5,480
    10,286
    Dec 15, 2010
    Lapeer, MI
    Dealer guy tried that one already.
  8. mitrucker
    5,480
    10,286
    Dec 15, 2010
    Lapeer, MI
    Thanks. I’ll have the guy try that next.
  9. mitrucker
    5,480
    10,286
    Dec 15, 2010
    Lapeer, MI
    Used to not be an issue, but my days start anywhere from 03:30 to 05:00 now, plus winter is coming. Lots of time driving in the dark.
    RoadRooster Thanks this.
  10. wichris
    4,492
    9,250
    Jan 17, 2011
    Maybe he needs to be better at it. Had our shop plug in and it was in there.
  11. mitrucker
    5,480
    10,286
    Dec 15, 2010
    Lapeer, MI
    Oh, it was in there. He disabled it with the computer, but the truck didn’t listen.
    I think another poster has the right idea. Leave it turned on for the four ways only.
