stuck at a scale over weight
Discussion in 'Experienced Truckers' Advice' started by l&s, Jan 31, 2015.
  1. l&s
    l&s Bobtail Member
    24
    4
    Jan 31, 2015
    i am stuck at a scale over weight and the shipper doesnt want me to break the seal what can i do??
  3. blairandgretchen
    13,946
    76,662
    Dec 9, 2011
    South west Missouri
    No way to slide tandems/5th wheel and correct weight - or are you over gross - or over on an axle . . . more info please!
    Contact the shipper - or your company. Chicken coups are chicken coups. You'll need some form of resolution before you can go. Typically it'll be pay the fine and go, or have a forklift and truck come out to adjust/remove some of load.
    TruckDuo Thanks this.
  4. 201
    201 Road Train Member
    12,787
    26,315
    Apr 16, 2014
    high plains colorado
    Hi l&s. not to chew you out, but unless the load shifted, you should have made sure you were right before you left. I know, too late for that now. Where are you over, gross, axle? If you can't get it right by sliding the 5th wheel or trailer axles, you are going to have to break the seal, and move the product by hand. ( I did that with lumber in a container once). You don't have much choice as they won't let you go until it's legal. Good luck.
  5. crankit2152
    crankit2152 Light Load Member
    88
    64
    Apr 2, 2009
    Scalemaster can break it and reseal it.
  6. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    5 yrs experience? C'mon....over gross or axle?
  7. l&s
    l&s Bobtail Member
    24
    4
    Jan 31, 2015
    i already slide the axles and the 5th wheel and still 1000 pounds over weight on my last axle
    blairandgretchen Thanks this.
  8. l&s
    l&s Bobtail Member
    24
    4
    Jan 31, 2015
    scale master doesn`t want to break the seal and reseal it !! bieing a real *******
  9. l&s
    l&s Bobtail Member
    24
    4
    Jan 31, 2015
    and yes my load shifted because i picked up the load in dallas tx and delivering it to san francisco and they stopped me in az and no problem there!!
  10. Trckdrvr
    Trckdrvr Heavy Load Member
    742
    621
    Dec 25, 2010
    Georgia
    What exactly does your weight show?
    Steer>
    Tractor>
    Trailer>
    Would love to help but need more info?
    TruckDuo, l&s and ramblingman Thank this.
