Stupid question to many!
Discussion in 'Experienced Truckers' Advice' started by Sherm117, Jan 11, 2017.
  1. Sherm117
    Sherm117 Light Load Member
    146
    61
    Nov 15, 2015
    Hey guys I have a stupid question to ask! I do not believe in a such thing as a stupid question, but I know some of you do so ill fire away. I have been in a automatic for some time now and truthfully it made me complacent as hell. lol. I'm switching to a super 10 transmission, and after a ton of practice and video watching I pretty much have the basics of shifting. I just have one question that I haven't been faced with so ill start now.
    Lets say I'm on the interstate and I run into a situation where I see brake lights ahead, and I'm in 10th gear in the real world working down from gear to gear doesn't seem like its likely to achieve when you really have to slow your rig down. can you more experienced guys chime in and let me know how you would handle this situation? like I previously stated I haven't been faced with this situation yet since ive been breaking in this tranny, but I know its coming lol.
    Thanks
  3. lagbrosdetmi
    lagbrosdetmi Box Monkey
    547
    988
    Jul 1, 2014
    Detroit
    10-8-6 stop.
    Assuming you actually know how to downshift. Is it the physical process you are confused on?
  4. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    You drop gear to gear to slow down gradually but in a rapid stop from 10th gear you will push the clutch in and brake until you stop or till you need to speed up, then you will shift into the right gear and keep going
    rank, roadrunningx18, tscottme and 5 others Thank this.
  5. Sherm117
    146
    61
    Nov 15, 2015
    Yes, its been a while. straight out of school I was in a manual for about a few weeks then been in a auto ever since.
  6. $16 Chauffeurs Lic
    $16 Chauffeurs Lic Light Load Member
    50
    28
    Dec 27, 2016
    practice on a parking lot up shifting and down shifting do it in low range,,get to where the shifts are smooth,,,if you can go up and down the gears in low range hi range will be easy,,as for down shifting when traffic slows it's a good thing to stay in a gear usually between 1300-1600 RPM for most trucks for the speed you are at,,right gear makes better control and today most trucks have engine brakes and they do help stopping or slowing,,an other thing is keep a safe following distance, many times just taking your foot off the pedal and letting the engine brake slow you is enough if you are keeping a good distance behind the vehicles in front of you.
    as for going down grades pick a gear when you have an engine brake that will hold you at a safe speed with out touching the brakes,,
    I used to run up and down the mountains in the rockies grossing over 130,000lbs and at 500,000 miles I still had 65% brake linings,,,make your time keeping your left door closed, plan your stops at the beging of the day and drive steady and easy
    uncleal13 and Ooops Thank this.
  7. miss elvee
    miss elvee Heavy Load Member
    816
    2,640
    Dec 15, 2012
    Russellville, AR
    Remember you don't have to drop gears in order, you can skip down like lagbrosdetmi said. How you downshift depends on conditions. ie: how much following room you have, how fast you're going, how heavy you are, road conditions, etc. With you already understanding how the truck wants to move and react during different conditions, I think you'll find it's like falling off a log.
    Get to know your tranny, each one is a bit different. Drop until you get to following speed. So in my tranny, if traffic slows to a following speed of 20mph = 6th gear. You'll get a feel for it pretty quick.
    Lepton1 and 201 Thank this.
  8. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    If you look far ahead and keep your eyes moving at all times then you'll be able to make smooth downshifts otherwise you may have to skip a gear but like I said look far ahead and always keep plenty of following distance.Treat the trk as if it's yours and be gentle with the shifting and braking.Super ten takes getting use to but once you got it it's easy.
    201 Thanks this.
  9. 201
    201 Road Train Member
    12,778
    26,291
    Apr 16, 2014
    high plains colorado
    Hey Sherm, listen to the ladies on this one. Unless you have an engine brake of some sort, downshifting doesn't do a heck of a lot. I know you're busy, driving and all, but the next time you are in a certain gear, try and make a mental ( or written, I suppose) note as to how fast you are going. After braking, it will give you a good idea where to start back up again. Biggest problem I've seen with newbies, is when downshifting, they tend to "over-rev" the engine. Remember, there's only a few hundred rpms between gears. Won't be long, you'll be "gear-jammin'" like the old timers.;)
    rank, OLDSKOOLERnWV, MACK E-6 and 2 others Thank this.
  10. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    What engine will you have?
    Engine brake?
  11. Powder Joints
    7,983
    8,384
    Sep 25, 2007
    Rosamond, SoCal
    Brakes are for stopping, you downshift in traffic when needed but for stopping or slowong down quickly, its the beakes
    rank and Lepton1 Thank this.
