Stupid question
Discussion in 'Flatbed Trucking Forum' started by BLHinshaw, Oct 23, 2015.
  1. BLHinshaw
    BLHinshaw Light Load Member
    127
    57
    Sep 28, 2012
    Graham, NC
    Where would I track down a few of those metal edge protectors I see guys use on coils? I've never seen them in the truck stops (and I'm sure I wouldn't want to pay the markup on them). I'm no flatbed rookie but the company I run with the past few years didn't run chains, so I've been getting coil supplies as I go the past couple months and those corners are the only things left on my list (i think)
  3. supersnackbar
    19,988
    51,930
    Aug 19, 2007
    Your Town, USA
    If you ever get by any of the Iowa80 truckstops, they have them. (Joplin MO, Kenly NC and Walcott IA)
    Sneakerfix Thanks this.
  4. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Cut up old mudflaps and old tires work well too.
    Hurst
  5. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    Add the chrome shop/blue beacon (x159 across from the Petro) in Effingham to the list of places that carry them.
  6. MACK E-6
    49,916
    237,091
    I was about to suggest that.
  7. terryt
    terryt Heavy Load Member
    736
    777
    Apr 27, 2009
    Almost any tarp shop or trailer dealer that sell flat beds usually is the cheapest place to find them and buy.
    barroll Thanks this.
  8. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    Pretty much any tarp shop, and a lot of trailer repair shops cover them. Chain guards are usually what I hear them called, but some call them steel edge protectors.
    If all you're doing is coils then you might want to look into a coil chain guard. You'll have a lot less trouble with them sliding around and falling off as you ratchet your binders.
    Ok big boy Thanks this.
  9. Flatbed Valkyrie
    Flatbed Valkyrie Medium Load Member
    567
    2,921
    Oct 25, 2015
    Chadds Ford,PA
    Chain guards is what I've heard them called as well.
    Iowa80 will over charge you for them like everything else.
  10. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Coil Cuffs may be what you're after. They make chaining heavy coils a lot easier, more chains in a smaller area, than corner protectors.
  11. Flatbed Valkyrie
    567
    2,921
    Oct 25, 2015
    Chadds Ford,PA
