Swift making it difficult
Discussion in 'Experienced Truckers' Advice' started by Cw5110, Jan 8, 2014.
  1. Cw5110
    Cw5110 Heavy Load Member
    875
    927
    Oct 19, 2013
    Georgia
    Hello all. So I decided to decline the offer of working under a fleet owner. He didn't like the I was "floating gears, downshifting" Course I was doing the way I was taught months ago and I know I've been taught right. So now I have to try to get a reinstatement from swift. Everything is still the same no accidents no speeding violations no DUI's and all that stuff. However when I sent in my reinstatement papers which was only like two sheets. I called the main terminal in phoenix and asked if they every received them just out of curiosity. Then they asked me did I fax them myself or did my Dispatch Manager fax them. I told them that I faxed them myself with the permission from the fleet mgr. Plus he gave me the number too their fax machine. So here they are telling me that my Dispatch Manager was suppose to fax them. I asked them why however they never could give them a legitimate answer. So my question too some if you may know. What should my next step be. Knowing the certain terminal that I run off of are the people with cut-off chicken heads. Sometimes I don't think they know any better. I would have thought that it would've been a simple process but now is turning into a clustef***. If anyone can help me that would be great. Appreciate it in advance.
  3. Chinatown
    Chinatown Road Train Member
    78,013
    185,977
    Aug 28, 2011
    Henderson, NV & Orient
    Are you set on staying with Swift? Why not shop around?
  4. Cw5110
    875
    927
    Oct 19, 2013
    Georgia
    It's most likely going too happen. If I they don't get it figure out. I've always looked into Conway and Schinder (I spelled it wrong I know)
  5. Chinatown
    78,013
    185,977
    Aug 28, 2011
    Blachowske Truck Line is hiring drivers that live in Albany. No tanker experience needed and it's not hazmat. Good looking trucks also.
  6. Silvermitts
    Silvermitts Light Load Member
    237
    124
    Apr 27, 2012
    Ga
    I'm guessing the reason they wanted your old fleet manager to do the faxing is they ( Phoenix ) would then know that he had no problem with your returning .
    I'm also guessing the person in Phoenix couldn't tell you why it's like that was never told
    why it's like that , which should come as no surprise to you .
  7. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Good grief,companies treat drivers like grade school children that can't do anything for them selves.What makes a difference who faxed the papers as long as they got faxed.
    Cw5110 and koncrete cowboy Thank this.
  8. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,909
    54,885
    Dec 8, 2012
    hunting...../ retired
    Goes back to the I , Me thing here...the owner of the trucks /fleet wants his drivers to double clutch...not an thing wrong with the owners expectations....after-all he IS the one paying your salary/wages.....the OP just didn't want to comply :smt017:smt017:scratch::scratch:......now it's someone else's fault he isn't working...when all he had to do was drive the owners equipment like the owner expected him to.....:dontknow:
    Moosetek13 and double yellow Thank this.
  9. Cw5110
    875
    927
    Oct 19, 2013
    Georgia
    And he also didnt want me downshift if you read it correctly
  10. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    Unnecessary downshifting does waste fuel. :biggrin_25518:
    LOL was you showing off by downshifting and jaking every gear?:biggrin_25520:
  11. oney1
    oney1 Bobtail Member
    39
    4
    Jan 12, 2014
    I only downshift when im loaded too hard on the brakes to slow down to 15 mph from 65 as for double clutching it saves waear and tear on the transmission because they are built different than the oldschool ones and will get tore up easy. Its cheaper to reace and adjust a clutch than to replace a transmission. Even a perfect shifter messes up sometimes.
