System Transport
Discussion in 'Report A BAD Trucking Company Here' started by mitmaks, Nov 4, 2017.
  1. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    I was at System Transport for 3.5 years. I started out as a company driver and saved every dollar I could as I was determined to go o/o. After 2.5 years I've bought my truck from them and leased onto them.
    They only have certain customers and won't look for loads and partials to get you better rate. If they have a stupid Genie/man lift that weighs ~35,000 lb and it will be on step-deck and you'll have 10ft upper deck and another 6-8ft behind manlift on lower deck-they won't find partials to get you better rate. Its take it or leave it deal.
    They charge 10% of each load just for the trailer. I ran hard and averaged paying them $1300/month just for the trailer. I just couldn't afford to buy my trailer at the time. If you lease onto System bring your own trailer as its just too much of money lost just for trailer rental and most of their trailers are junk, lights not working, tires are bald (they only run recaps) if for some reason you got a trailer with 2 new tires its cause there was blowout and road service replaced with 2 new tires.
    Preplanning loads at System is nonexistent. If you pick up one of their loads from Spokane and head over to MO or KS for example, you will most likely sit after you're empty from several hours to a day.
    Deadhead is what will hurt you as they might offer you load that picks up 200-300 miles away. They don't look for loads on loadboards and you're stuck with their regular customers.
    I wouldn't recommend them for owner/operators. They expect you to work for pennies here.
    Rugerfan Thanks this.
  3. Gunner75
    Gunner75 Road Train Member
    5,701
    9,076
    Mar 17, 2014
    Jackson Center Ohio
    Isn't the main concern for companies like system to take care of their customers first?
    Lonesome Thanks this.
  4. mitmaks
    2,586
    2,102
    May 16, 2014
    Possibly but they have to keep their o/o busy as well. They literally have dozens of loads sitting at the yard cause they pay so low, otherwise other companies would grab them.
    And for the record I've always picked up/delivered on time and have 100% service.
  5. Gunner75
    5,701
    9,076
    Mar 17, 2014
    Jackson Center Ohio
    So they actually charge am additional 10% of each load for trailer rentals
  6. mitmaks
    2,586
    2,102
    May 16, 2014
    Its 28% of load if you don't have a trailer and 18% if you have your own trailer.
    Company I went to lease onto now charges 10% for dispatch service and they actually have dispatchers looking for loads for YOU as an owner operator cause the more expensive loads the more $$ myself and my dispatch will make, its a win win situation.
  7. White Dog
    White Dog Road Train Member
    3,161
    3,807
    Feb 11, 2008
    Iowa
    If you were with them for 2 1/2 years...why didn't you pick up on how they ran?
    If they never searched for partials to increase revenue to THEIR truck; what makes you think they'd do it for YOUR truck?
    The "trailer rental" should have been discussed and agreed to BEFORE your surprise on the first check.
    And the rest of the stuff you talked about should have, and could have been learned in 2 1/2 years as well.
  8. Hoofbeats
    Hoofbeats Road Train Member
    1,250
    1,991
    Jan 27, 2010
    Iraq
  9. Rugerfan
    Rugerfan Road Train Member
    7,745
    39,684
    May 3, 2011
    Redding,CA
    That was always the biggest problem as a company driver with them. Sit for hours waiting for a new load sometimes.
  10. Oil Slick
    Oil Slick Bobtail Member
    23
    8
    Aug 13, 2017
    What company are you working for now?
  11. mitmaks
    2,586
    2,102
    May 16, 2014
    Small local company that has ~20 trucks.
