T660 turn signal/flasher problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Dec 14, 2015.
  1. mitmaks
    mitmaks Road Train Member
    2,570
    2,087
    May 16, 2014
    You take a small screwdriver and pry contacts apart so theyre snug against pigtail once connected to the trailer
    Sho Nuff Thanks this.
  3. Sho Nuff
    Sho Nuff Road Train Member
    1,175
    1,402
    Apr 9, 2015
    I agree with that. Did it plenty of times myself.
    Usually when you connect to a trailer, you want a tight fit. If you can move it around to the point when it starts affecting the lights, it's time to get a new pigtail.
  4. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    This went from tractor flashers to how to fix a loosen pig tale with a screwdriver.
    How long have they not worked for? Could be as simple as the bulb being in the wrong way or relay to power supply. Let us know.
  5. Sho Nuff
    1,175
    1,402
    Apr 9, 2015
    Were you connected to the trailer at the time the tractor hazards stop working? I was assuming that you were.
  6. mitmaks
    2,570
    2,087
    May 16, 2014
    KW dealer said its bad chassis node.
    #### these engineers who design these trucks
  7. Thed302
    Thed302 Light Load Member
    114
    70
    Oct 30, 2014
    USA
    We rarely see these go bad, I think I've only seen one go bad once since I've worked for my KW dealer. On our side, having a chassis node and computer-controlled everything is awesome. But for drivers that don't have the software to work on them it's a pain in the ###.
  8. mitmaks
    2,570
    2,087
    May 16, 2014
    Then ehatever can go wrong on this truck-eill go wrong. Wish Id be driving Peterbilt. KW quality went to crap long time ago
  9. boneebone
    boneebone Road Train Member
    2,297
    2,370
    Mar 13, 2009
    Peterbilt/KW is still Paccar, to cut down on costs and R&D, I'm sure they share alot of the same Electronic and electrical parts.
    Anything made in these modern times are pure junk, they only make it to last a certain lifespan, and when it starts falling apart you throw it away so they can sell you another one.
    That's how Companies stay in business.
  10. Thed302
    114
    70
    Oct 30, 2014
    USA
    NGP Peterbilts and KW's (T680, T880, 579, and 567) are electrically all the same. Some of the harnesses even use the same part numbers, but all of the harnesses use the same connectors, wiring, and pin locations. Before there were two different engineering teams working on each brand and they rarely collaborated. That means if you compare a 389 to a W900, they'll be very different.
  11. mitmaks
    2,570
    2,087
    May 16, 2014
    They installed new part and flashers still wont work. They dont know what the problem is but its electrical. What a pile of #### and truck is barely 3 yrs old.
