T660 turn signal/flasher problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Dec 14, 2015.
  1. Thed302
    Thed302 Light Load Member
    114
    70
    Oct 30, 2014
    USA
    Like I said, chassis nodes rarely go bad. Tell them to disconnect the CECU and turn the key on. The chassis node will automatically turn the headlights and four-ways on. This way you can eliminate the node and external wiring if it lights up.
  3. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    I believe I drive a lemon. Im just worried getting home for Christmas
  4. mitmaks
    2,586
    2,102
    May 16, 2014
    Kenworth selling pile of crap that they cant fix
  5. dbowman7720
    dbowman7720 Bobtail Member
    I have the exact same problem on a 2012 T660. When problem started...it was intermittent...now front signals do not function at all; however, all other turn signal everywhere else on vehicle work including when hooked to a trailer.!
  6. Kjjmc
    Kjjmc Bobtail Member
    Need help , im having the same problem on a 2012
    kw t660 did you fixed it?
  7. mitmaks
    2,586
    2,102
    May 16, 2014
    Wiring problem. My truck was at KW stealership for 3 days. They had to rewire it
  8. XRESETX
    XRESETX Bobtail Member
    15
    10
    Sep 4, 2012
    I went thru this entire thread for an answer to my 2006 T660 no Flasher/Turn Signals, watched every available video on the net and FINALLY figured it out AFTER taking the truck to the Stealership and getting horsefreaked out of $560 and STILL had no Turn Signals. OK, the deal was I swapped out the batteries and my ratchet handle hit the side of the box while on the positive post and sparked ONE TIME. That's all it took. Yeh, shoulda, coulda, woulda made sure the ground was disconnected first, but I didn't. Anyways, be sure to check all the fuses and relays in your fuse box and eliminate that possibility, then in the CENTER of the Dash--pull off the plastic bezel around the instrument cluster and unscrew 4 screws and pull out the panel and look for a 6" x 5" black box with a dark blue front with 2 plugs hanging out--the entire box is NOT secured, just hanging deep in the dash, about where the cup holder is. The part number varies by a single digit, but mine is: P21-1019-303, PACCAR. Others end in -203 and -103. On Ebay and general search on Google, the price for this "PC/ABS" module varies from $450-$600 and surprisingly, a new one is "only" $606 after taxes from the Stealership. Plug 'n Play--so for $1160 later, everything works. The worst thing was the truck wouldn't start right after the battery incident, took it in to the Stealership, they got it to crank, but the Turn Signals were going to be a separate issue and an additional charge and their fancy computers were unable to diagnose the module failure, so I was going to be charged time and material for the FNG new hire to find the problem @$125/hour. The joys of trucking, part #109936471...
  9. XRESETX
    15
    10
    Sep 4, 2012
  10. J-trucker
    J-trucker Bobtail Member
    Did you ever find a resolution for this? I got a 2014 doing the same thing. Sometimes front blinkers are inoperative but only intermittently. More so when the engine is on.
  11. mitmaks
    2,586
    2,102
    May 16, 2014
    Like I've posted in above replies truck was at dealership 3 days. They rewired it and I was on my way after 3 days
