Tarp help...
Discussion in 'Flatbed Trucking Forum' started by earnies2, Jun 9, 2021.
  1. earnies2
    earnies2 Medium Load Member
    691
    281
    May 17, 2012
    Dedham, MA.
    I carry 3 16x24 tarps. That are in good condition. I also have a smoke tarp.
    And when I bought my flatbed it had 2
    20x26with a 6x8 flap..they are not in great shape.
    My question is what am I doing wrong.
    Today I hauled a steel tubing load they were 48 footers 3 foot tall. 2 of my 16x24 tarps didn't do it i needed to put the smoke tarp in the middle. I didn't want to use 3 tarps. And my 20x26 tarps aren't great.
    Should I just buy 2 new tarps that are long enough to cover the load with a 4 foot drop or a 6 foot drop? And what's your thoughts on the newer tarps with the lightweight sides?
  3. Kyle G.
    Kyle G. Road Train Member
    3,901
    20,575
    Jan 23, 2016
    Eastern Iowa
    If your load is 48 ft long then two 24 ft tarps would not be long enough. They have to be able to overlap.
    Also, when you use more than one tarp, you need to tarp the back of the load first, then work your way up, so the front tarp overlaps the back tarp. That way as you are going down the road the wind and rain can't work their way under the tarp.
  4. Judge
    92,282
    earnies2 Thanks this.
  5. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    My tarps are 27' long. That can cover 53' with a 1' overlap. If you get new tarps, I'd get two of those, instead of three shorter ones. And at 27', you can cover 12 pallets with one tarp.
  6. xsetra
    xsetra Road Train Member
    5,197
    7,148
    Aug 21, 2011
    I had a 3 piece light weight 8' drop set of tarps. Both end pieces had the flap and a smoke tarp. They were easy to move around. Most of my tarping was on machines and port crates. Odd sizes. I didn't do many loads that required 4' - 6' drop.
    I still carry my smoke tarp but stopped carrying the larger set, they rest in the shed.
    With the light weight drop tarps. If you have water puddling on the sides. It will seep through, If it sits for a couple hours. I didn't have trouble while driving. The tarp sheds the water while moving. You can treat the tarp with a product for Tents to repel water.
    Good luck
  7. Linte_Loco
    Linte_Loco Road Train Member
    1,618
    6,485
    Apr 24, 2011
    LA (lower Alabama)
    Look for 26” wide at least. Covers 8`6”tall and wide loads. Length at least 27. Can’t stress the width enough
    God prefers Diesels and earnies2 Thank this.
  8. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    Those tarps are expensive but probably worth it
    Judge Thanks this.
  9. Linte_Loco
    1,618
    6,485
    Apr 24, 2011
    LA (lower Alabama)
    Some people hate big tarps. I get it lol. Worth it IMO to have 2 sets big wide and long, and the simple “steel” tarps
  10. Judge
    92,282
    Lightweights are worth it IMO, sometimes tarp shops can be cheaper, if around west Memphis area a place called best tarps used to be reasonable, haven’t bought flatbed tarps in a few years.
  11. Qbf594
    Qbf594 Road Train Member
    1,642
    8,715
    Aug 15, 2019
    Southern Canadian annex, NY
    I'm just starting the lightweight tarp learning curve. I'm going to add a moving blanket and a painter's cloth I saw at Lowe's that has anti slip dots all over. I have felt pieces but the last load was slick stuff that I couldn't tape or stick the felt so it moved and I got some corner tears. I think the felt might stay put if it's over a canvas drop cloth.
    But for the extra steps needed they are still so much easier to move its worth it. 14oz all over. 8ft lumber 2pc set. 27ft long ea on my 48ft deck cover everything fine.
