Tarps
Discussion in 'Ask An Owner Operator' started by Bran723, Feb 16, 2019.
  1. Bran723
    Bran723 Bobtail Member
    19
    Jan 1, 2019
    Question. Does anyone know where we can get tarps that are still heavy duty with either a 6' or 8' drop but not weigh 80lbs. I've seen some on 18 wheelers where they have smaller ones but more quantity. We have a 40' trailer just trying to find some a little lighter it's hard to get these up on top when the loads 8' tall appreciate the help
  3. Rickp
    Rickp Heavy Load Member
    765
    1,070
    Apr 14, 2016
    Ward, AR
    80 lbs is probably light for an hd tarp.
    Tb0n3 Thanks this.
  4. Espressolane
    18,732
    117,474
    Have the fork lift driver put them up on the load.
  5. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    80 pounds sounds pretty light for a lumber tarp. I don't see how you could get any lighter. Thats a lot of material.
  6. Long FLD
    Long FLD Road Train Member
    12,935
    54,276
    Mar 4, 2015
    Light and heavy duty are rarely used in the same sentence. I’m assuming you have two tarps now, one option is to run 3 smaller ones instead.
    Tb0n3 Thanks this.
  7. Gentlemanfarmer
    Gentlemanfarmer Medium Load Member
    365
    384
    Feb 26, 2010
    Greenville, FL
    Most tarps are made of 18 ounce vinyl. You can go lighter with 14 ounce vinyl but be prepared to make a lot of repairs. Contact companies like Tarp Stop, Duroche Tarps. If you have a 40 foot trailer, then you could get two 20 foot tarps to reduce the weight. Most truckers use two 24 foot tarps of 18 ounce vinyl (6 or 8 foot drops). You can also get a light weight 8 foot drop in three sections.
    Tb0n3 and Truckermania Thank this.
  8. roshea
    roshea Road Train Member
    Two 24 footers would be more appropriate to allow for overlap. Two 20's would not properly cover a full 40 ft load. Two 24's will not cover a 48 ft load, but 27's will
    Tb0n3, Gentlemanfarmer and Opendeckin Thank this.
  9. Bran723
    19
    Jan 1, 2019
    Ok thanks sorry I'm a female and those babies are heavy to be tryin to toss around. Lol you all must have some muscles ☺️
  10. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    It would be better for you to use 3 pieces to reduce the weight especially if you are tarping a lot. It will help you in the long run. If you can afford it & you're in it for the long haul. A conestoga is your best bet. All the best to you.
  11. Ruthless
    Ruthless Road Train Member
    9,201
    91,388
    Aug 28, 2010
    The City.
    Man or woman: you want to flatbed you better be able to figure a way to get it done. Build the muscles and carry a ladder, or have the forklift put the rags up top. If it ain’t you it’ll be someone else.
    And DON’T fall.
    Tb0n3 and Humblepie Thank this.
  12. Espressolane
    18,732
    117,474
    Some truths have been shared here.
    roshea Thanks this.
