Temp on empty trailer
Discussion in 'Refrigerated Trucking Forum' started by Greggg, Apr 9, 2019.
  1. Greggg
    Greggg Light Load Member
    161
    35
    Jun 30, 2018
    looking to buy my own reefer. Was wondering what temperature should an empty trailer go down to in 75-80 Fahrenheit?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    It does not matter what the outside temp is provided everything is in order. Particularly the integrity of your trailer. You can usually get down to -20 after a period of some hours inside that thing ready to accept a load. The trailer knows what the outside air temperature combined with the heat index is. And will do it's best to meet your set point. Ive had trailers working in a apparent 145 to 160 degree environment some days at the catwalk.
    What you cannot do is chill 80 degree product to -20, it will use up so much time and burn all of your money trying to do it.
    Farmerbob1 Thanks this.
  4. Greggg
    161
    35
    Jun 30, 2018
    Thanks, good to know :)
    Re reading I guess I didn’t ask my question right though. Was wondering within an hour or two max.
    Since I can’t burn the diesel of the person I’m buying from a whole day or so let’s say.
  5. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    If you are trying to cool the trailer to a temperature to load 70,000 dollars in say Ice Cream, Frozen. A few gallons of fuel is the least of your anxiety. Cool that thing.
    Omega1 Thanks this.
  6. Greggg
    161
    35
    Jun 30, 2018
    What I meant is doubt anyone selling their reefer trailer will let somebody leave their trailer running for as many hours as we want
  7. Omega1
    Omega1 Heavy Load Member
    721
    1,598
    Nov 18, 2017
    Oregon
    I think any seller of a refer will understand your need to test the unit and won't have any issues with you running it for a few hours. My refer will burn about 9 to 10 gallons in a 24 hour period set at -10 continuous in the summer time. Just saying.
  8. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    If I was selling a trailer say for 40,000 dollars (Pulling a price out of a hat...) to you, and you aint happy until you can see first hand what it can do to cool... let it run I say. The fuel loss aint nothing.
    It's a lot better to prove it to you in actual cooling than to kick the tires like a shyster salesman trying to con and pressure you into buying a trailer you know nothing about.
    NavigatorWife Thanks this.
  9. reeferwrencher
    reeferwrencher Medium Load Member
    613
    1,577
    Aug 4, 2018
    Buy an TK SB 230 or SB 330.Other then the head gasket issue they are easily the best reefer ever made.
  10. Greggg
    161
    35
    Jun 30, 2018
    What do you guys think about 2009-2011carrier 2100 ? Are they good for frozen loads ?
    How would it compare to an older carrier ultra xtc ?
  11. reeferwrencher
    613
    1,577
    Aug 4, 2018
    They're good too,just make sure the exhaust manifold isn't cracked before you buy it. It's alot of work to replace it.
