Temperature problems
Discussion in 'Volvo Forum' started by Insurrecto18, May 28, 2022.
  1. Insurrecto18
    Insurrecto18 Bobtail Member
    4
    5
    May 28, 2022
    Hi, I have a problem driving me crazy about the temp in the engine. Is a Volvo 2018 d13 500hp 650k miles on it. My problem is the truck is running way too hot. Radiator is new water pump new thermostat new coolant filter new. When the outside temp is over 60F. The truck is running on 210F and above the most I’ve seen it is 220F. The fan clutch kicks around 210 some times 220 but the temp doesn’t go down it just stop the temp to keep raising. Any advice where I should look for.
  3. Judge
    91,633
    clean out the condenser in front of radiator.
    Degreaser, leave it for 3-4 minutes and high water pressure to clean it, don’t concentrate on one area with high pressure or you’ll bend the fins.
  4. Insurrecto18
    4
    5
    May 28, 2022
    It looks clean I can see through the condenser
  5. AModelCat
    164,279
    220 is not really excessively hot if you're pulling hard up hill with the fan on.
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Shoot it with a temp gun to make sure the guage is reading correctly.
  7. Six9GS
    Six9GS Road Train Member
    1,473
    3,697
    Dec 3, 2012
    Yuma, AZ
    IDK, sounds to me like you have the wrong thermostat. But, that's from the perspective of a car guy. Plenty of experience wrenching on cars, none on a rig. So, my answer may be in left field. But, for a 4 wheeler, wrong thermostat would be my quess from the information provided.
  8. Longhaullover
    Longhaullover Bobtail Member
    11
    12
    Jul 2, 2020
    I would get the themostat replaced because that is the part that controls the coolant flow in the system. if its stuck close your coolant wont flow through the radiator and hence overheating problems
  9. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,266
    Nov 14, 2021
    ALBERTA
    I would check in a road test with a tech tool plugged in the intake manifold temp.
    If it's too high, it will raise the engine temp too.
    And I would check for how long the EGR valve stays open. 30-40%? 100%?
    And I would check and test the EGR cooler flow and efficiency.
    Just to start.
    Insurrecto18 Thanks this.
  10. Insurrecto18
    4
    5
    May 28, 2022
    I just saw the temperature is going up when the exhaust temp is over 550. If I can keep it under 550 the engine temp doesn’t goes up. Do you know by any chance the exhaust temp range ?
  11. Insurrecto18
    4
    5
    May 28, 2022
    I don’t think is the thermostat because going downhill the temp goes down immediately
