The lousy D13 engine brake
Discussion in 'Volvo Forum' started by 86scotty, Aug 4, 2019.
  1. 86scotty
    86scotty Road Train Member
    4,706
    12,916
    Aug 27, 2017
    Appalachia
    Been meaning to post this awhile. I'm really curious how much RPM abuse I should throw at my D13.
    Having driven Detroits and Cummins before this truck (2015 780) I'm blown away by how weak the engine brake is. I know how to use it, with the 1/2/3/max settings or just engaging the downhill cruise but it doesn't ever seem happy, it's either way too little or too much at way too high RPM's.
    I-shift hardly ever lets my truck see over about 1600 RPMs but to get any engine braking at all on this motor with a heavy load you have to bump it to 3 or max and it shoots the RPMs up to 2100 and sounds like it's going to explode. I hate doing this. Is it ok for this motor? It just doesn't make sense to me becuase you never want to run a big diesel up to nearly 2k RPMs but in engine brake on these it seems like you have to.
  3. supersnackbar
    20,106
    52,673
    Aug 19, 2007
    Your Town, USA
    On engine braking, RPM's are good...up to a point. The owners manual for the old International Maxxforce engine said optimal engine braking was achieved between 1900 & 2150 RPM's. My MP8 Mack with the mDrive will downshift down to 10th and run the revs to 2100-2200 if 11th or 12th doesn't hold me back. And my truck is just a Volvo in a Mack costume.
    86scotty and Newto Trucking Thank this.
  4. 86scotty
    4,706
    12,916
    Aug 27, 2017
    Appalachia
    Just seems way too high for a diesel but I guess I’ll get used to it.
  5. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    FYI .... You can adjust the engine brake strength in the parameters with a Volvo...
    I usually like;
    #1 60% area
    #2 85%
    #3 100%
    (A) Mode 85%
    They are most effective 1300-1800rpm .....if you have noticed higher RPM they don't work very good and lose strength above 1800
  6. KB3MMX
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Fyi.... The D13 and Mdrive/iShift is produced at the MACK plant in Hagerstown MD , 100% USA Mack.....
    (Identical engines except for plastic badges and final paint color)
    The Mack powertrain is awesome in Volvo trucks
  7. KB3MMX
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Yes above 1800 you can feel the loss of engine brake power in D13/MP8
