Thermo king apu ENG code
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Jun 26, 2019.
  1. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    What can I check on my pay it has eng code and won't start. Tried pressing reset button and it won't fix it this time
  3. Dave_in_AZ
    428,274
    Could be a number of things. Take the access cover off and see if the belt is still in place. Lots of times it will call it quits if the alternator isn't putting out.
  4. mitmaks
    2,586
    2,102
    May 16, 2014
    Belt is fine. It doesn't even try to start. When I turn on control panel it will display ENG several seconds later.
  5. Dave_in_AZ
    428,274
    Bad alternator would be my guess. Oil level ok? Coolant?
  6. Dave_in_AZ
    428,274
    Could be a sensor too. Guys in Phoenix at Arizona Laser Alignment are tri pac masters, and do stuff for a fraction of what TK charges.
  7. Dave_in_AZ
    428,274
    If you are feeling embolded, take the cover off that black box where the reset button is. Inside are fuses. Look for blown fuse. Those fuses go to different sensors.
    mitmaks Thanks this.
  8. mitmaks
    2,586
    2,102
    May 16, 2014
    Except it doesn't say which fuse is for what
  9. Dave_in_AZ
    428,274
    No you need the manual. But look to see if any are blown. I had the oil level sensor go bad. Kept blowing the fuse triggering the ENG fault. It's like a $17 part.
    Now TK is going to turn that into $800 job.
  10. Dave_in_AZ
    428,274
  11. bavarian
    bavarian Heavy Load Member
    730
    785
    Feb 13, 2014
    Winnipeg
    Copy all above. Make sure the safety switch in the engine compartment is on.
    Good luck.
