This happened yesterday in town
Discussion in 'Trucking Accidents' started by Dennixx, Mar 3, 2019.
  1. Dennixx
    Dennixx Road Train Member
    4,549
    14,636
    Feb 13, 2010
    twin cities
    Farmerbob1, PE_T, Lepton1 and 2 others Thank this.
  3. Diesel Dave
    9,716
    33,176
    Jan 20, 2010
    Hesperia, Ca.
    Straps on a load of steel ? I have seen a lot of that lately, wtf !!! And if you have various size is diameter, your supposed to throw a complete wrap around belly wrap, at least I do. And those look like those 2” straps on that load. Anyways...... RIP driver, very young driver.
    Farmerbob1, Lepton1, mjd4277 and 4 others Thank this.
  4. Dennixx
    4,549
    14,636
    Feb 13, 2010
    twin cities
    I haven't hauled steel for awhile but I thought we were required to have a bulkhead or headache rack back in the 70s with our COEs
  5. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    As far as I know it's not required anymore. Back then it was.
    Lepton1, lovesthedrive and Dennixx Thank this.
  6. kemosabi49
    10,985
    47,947
    Jan 13, 2013
    SW Arkansas
    Still may have slowed that load down enough for that driver.
    Farmerbob1, Lepton1 and lovesthedrive Thank this.
  7. QuietStorm
    QuietStorm Heavy Load Member
    899
    1,416
    Dec 11, 2016
    You pay for laziness with your life. RIP
    lovesthedrive Thanks this.
  8. fss99701
    fss99701 Medium Load Member
    327
    663
    Feb 14, 2019
    none of your business
    Even extremely well secured loads can shift during hard braking. This is why anybody transporting steel beams or pipe should use a truck with a headache rack, they're worth the money in the life they save could be your own.
    I would never transport steel beams or pipe without a good headache racks installed on the truck it's not worth your life.
    Farmerbob1, Lepton1, allniter and 3 others Thank this.
  9. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Looks to me like he made a good attemp to keep the beams cinched together tight. But keeping sufficient friction on the inside upper pieces to hold in an abrupt stop is hard no matter what all you do. I doubt chains would have made any difference in this ultimate outcome. However with large I-beams such as these, a chain “x-strap” can usually be put in place that will hold at least a few of the inside upper pieces that worried you the most.
    If given another chance he would probably at least invest in a headache rack
  10. fss99701
    327
    663
    Feb 14, 2019
    Headache racks used to be required. About 10 years ago when the big carriers finally bought off enough people in Washington they were able to dictate their own regulations, that requirement went away.
    The pic above is a truck that the driver's life was saved with the headache rack countless people have been saved by headache racks. The fact that some carriers mostly local are too cheap to invest a few dollars in a headache rack is retarded. if you're going to haul a flatbed with steel it's an absolute necessity.
    I'm not saying they're foolproof but they definitely improve your chances of surviving significantly.
    Farmerbob1, Lepton1, mtoo and 3 others Thank this.
  11. Pedigreed Bulldog
    7,737
    14,424
    May 7, 2011
    Whenever the weather cooperates, I don't even have a piece of glass between me and the load...
    Properly secure the load & drive like you're supposed to and it isn't an issue.
    Lepton1, BigCam9670 and lovesthedrive Thank this.
