This prostar is driving me insane.
Discussion in 'US Xpress' started by jman82, Apr 6, 2015.
  1. jman82
    jman82 Bobtail Member
    11
    Apr 5, 2015
    What is with the random, loud as hell release noise directly under my bunk?!
    I wish I drove a freightliner. Maybe I'll get lucky and this turd will break down.
  3. skyviper73
    skyviper73 Heavy Load Member
    735
    589
    Feb 17, 2012
    Centennial, CO
    Be careful what you wish for. The truck may leave you many miles and hours from help. That's not easy on the bank account.
  4. jman82
    11
    Apr 5, 2015
    I just wish this #### thing would shut up so I could sleep.
    Every 7 seconds a load pressure release noise happens below my bunk. I know my neighbors are pissed, but the "bunk heater" cooling fan isn't good enough for a comfortable sleep.
  5. Chinatown
    Chinatown Road Train Member
    77,965
    185,501
    Aug 28, 2011
    Henderson, NV & Orient
    Air dryer problem.
    blairandgretchen Thanks this.
  6. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    Is it your trainer trying to get out?
    paul_4lp, Ditch Doctor and CargoWahgo Thank this.
  7. OldHasBeen
    OldHasBeen Road Train Member
    1,269
    924
    Dec 16, 2010
    That’s true, once I was going south of Indio, CA, on a deserted strait stretch and my engine died all of a sudden. I was very happy I pulled over quickly and stopped.
    After I got stopped I found out something shorted out the batteries and I had no juice at all.
    I happened to think, if I turn my Cumming fuel pump on manual, and if my truck will roll forward, I might be able to get it started and go on.
    I did so, them put it in 5 gear, released the brakes, for a few seconds it just set there, finally it started to roll forward, them I got it started, and I went on my way.
    When I got to a shop I found out the parallel switch shorted out. Wow, was I fortunate it rolled far enough to get it started.
    Could that be done on the modern day trucks?
    TruckDuo Thanks this.
  8. devildriver66
    devildriver66 Bobtail Member
    36
    24
    Mar 21, 2015
    Uhhh...NO.
  9. belowspeedlimit
    belowspeedlimit Medium Load Member
    648
    611
    Oil country
    I've always said international should have stuck with making farm implements.
    Chinatown and tucker Thank this.
  10. Dna Mach
    Dna Mach Road Train Member
    3,304
    3,162
    Aug 8, 2008
    Texas
    Is it air popping? If so you're air governor is stuck. I guarantee you, the driver parked next to you is even more annoyed with it. :biggrin_2559:
  11. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,425
    Mar 23, 2012
    Whenever a pr
