Trailer clearance lights out
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Qbf594, Apr 23, 2021.
  1. Qbf594
    Qbf594 Road Train Member
    1,642
    8,715
    Aug 15, 2019
    Southern Canadian annex, NY
    Since all 5 top across the back clearance light and the red lights at the rear right and left side are ALL out that seems like a fuse.
    I don't see a listing in the fuse panel (cab-2018 Freightliner) for ANY trailer wiring except ABS.
    Am I looking in the wrong place?
  3. SmallPackage
    5,786
    18,579
    Dec 20, 2019
    Marion Texas
    Usually the black wire in the pigtail or trailer plug.
    Magoo1968 and AModelCat Thank this.
  4. Qbf594
    1,642
    8,715
    Aug 15, 2019
    I'll see if I can find it. Thank you
  5. SmallPackage
    5,786
    18,579
    Dec 20, 2019
    Marion Texas
    The brown one usually if wired correctly will power the lower tail lights, side markers, and license plate light. The black powers the others.
  6. Qbf594
    1,642
    8,715
    Aug 15, 2019
    Ugh. Not like a flatbed trailer. Can't follow anything. Everything is up inside the trailer structure or maybe in the bulkhead wiring box. Guess I'm asking boss man to take it from here LOL
  7. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    There is a fuse or two for the trailer on the firewall in the engine compartment. Drivers side up by the air manifold.
  8. NorthEastTrucker
    NorthEastTrucker Road Train Member
    1,019
    1,927
    Sep 21, 2019
    As others mentioned check the fuses but I had a similar issue and it was the pins on the trailer couple that had an issue. Another issue was the electric couple prong pins.
  9. Qbf594
    1,642
    8,715
    Aug 15, 2019
    I'm guessing it's this. I had to back up like I was a proficient city reefer driver...except I'm only an ok flatbedder and I pulled the pigtail so hard the plastic deformed! I replaced the cord but might have stressed the pins. (Horrible inner city Atlanta warehouse you have to jackknife and keep pushing to square up to the dock. I don't even know why that's a thing FFS ...get a straight truck...)
    Anyway. Thanks for the input. I'm handing this off the guy who owns this problem LOL it's above my pay grade.
    NorthEastTrucker Thanks this.
  10. NorthEastTrucker
    1,019
    1,927
    Sep 21, 2019
    Not a problem. Back in the day (One of my last Otr routes for a form company I worked for) I had a reefer load going to a Cold storage in the Atlanta area so I can understand your frustration.
    Qbf594 Thanks this.
  11. blairandgretchen
    13,933
    76,592
    Dec 9, 2011
    South west Missouri
    Thin blade screwdriver and spread the prongs in the male end ?
    haycarter, AModelCat and Qbf594 Thank this.
