Trailer hitting frame and tires
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gabrieldjr, Mar 9, 2020.
  1. Gabrieldjr
    Gabrieldjr Bobtail Member
    5
    Jan 22, 2019
    When I make a tight turn my trailer will get stuck on the tractors frame and or tires. Its pretty bad almost shuts off the truck from the trailer weight hitting the drive axle tires.
    Dont know specs to well but the semi is a 2012 Coronado. 3 axle.
    Pulling a walking floor for ag commodities. what can I do to fix this.
    truckdriver31 Thanks this.
  3. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Check ride height. Is air spring bags inflated?
  4. xsetra
    xsetra Road Train Member
    5,197
    7,148
    Aug 21, 2011
    Move your 5th wheel away from cab. If you can, keep weight distribution in mind.
  5. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    If this is a new problem check the ride height suggested by Snailexpress. If you've just paired this truck to the trailer. You may need to add a block between your 5thwheel and frame.
    truckdriver31 and magoo68 Thank this.
  6. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    It may seem obvious (or not) but is your suspension switch in the 'up' position? Up as in not dumped.
  7. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Check overall height see if you can run a higher profile 5th wheel?
  8. SmallPackage
    5,807
    18,612
    Dec 20, 2019
    Marion Texas
    Some live bottoms and grain belly hoppers require the fifth wheel to be up to 4 inches higher for tractor clearance.
    Snailexpress Thanks this.
  9. Judge
    92,310
    When I pulled a hopper, I got two pieces of heavy duty steel tubing,length of the 5th wheel, then had holes measured and drilled at machine shop, and raised 5th wheel almost 4.5 inches.
    Snailexpress and SmallPackage Thank this.
  10. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    probably need a taller 5th wheel.
