Trailer tire came off
Discussion in 'Trucking Industry Regulations' started by AllDownHill, Mar 7, 2024.
  1. AllDownHill
    AllDownHill Bobtail Member
    Mar 7, 2024
    So traveling down the road driving at night on a poorly lit 4 lane highway I see barely off in the far distance of a vehicle behind me a few miles back a puff of smoke and what feels like I hit a wavy portion of road and the trailer is feeling kind of bouncing I pull over to see if I blew a tire but not instead the dual tires came completely off the spindle for the tire bent DOT bumper broke my license plate holder and bent my mudflap. Called company sent pictures and I was told to drive it slowly 14 miles back with flashers on and if I’m stopped by DOT or police to have them call into the company. I’m refusing to move vehicle and basically night dispatch told me it’s either I drive it back 14 miles or sit on the side of the road. I’m risking the other tandem trailer tires to heat up not to mention there’s no hub oil in the rear axle of the tandem. What would you do in this situation? I’m nowhere near a safe place just stuck
  3. Flat Earth Trucker
    4,335
    16,745
    Nov 19, 2018
    I won't do it, but you are about to be read the riot act about not performing an adequate pre-trip inspection.
  4. AModelCat
    165,090
    Oil isn't shared L to R on trailer axles.
  5. 062
    062 Road Train Member
    6,347
    34,012
    Oct 20, 2013
    I would chain it up.
    Depending on the damage and availability of a axle surgeon,you’ll likely be sitting a couple days.
  6. 201
    201 Road Train Member
    12,824
    26,408
    Apr 16, 2014
    high plains colorado
    That's pretty serious, dude. It's entirely possible, there was no way of knowing or preventing that, a bearing can and will seize, but more than likely you will get the blame for not checking axle hub oil. Quite frankly, you dodged a bullet there, my friend, hopefully the duals ended up in the ditch, and not in some families minivan coming home from church,,,or whatever. Bearings usually fail from metal in the oil, causing a seal failure, and oil all over. Was any service done recently? I've seen axles chained up before, but I think today, a cop will require a wrecker or service truck. Just looks bad, chained up axle, therefore in their eyes, it must be. I wouldn't move either these days, and sadly, I bet the company hangs you for this.
    JoeyJunk Thanks this.
  7. Grumppy
    3,248
    11,512
    Dec 11, 2010
    West Monroe, La
    Dont take this as being rude, but..... If you gotta ask.. If you dont know how to handle this safely... if you're afraid/uncomfortable in attempting to move it safely... If you dont have the knowledge or equipment (chains etc)....
    put out triangles, stay put & call a wrecker to get it moved safely.
  8. tarmadilo
    tarmadilo Road Train Member
    1,733
    4,775
    Dec 12, 2018
    I’ve had similar situations. If you can limp forward a short distance to a safer place to get it off the road, do so. But otherwise get those triangles out and flashers on and have them send help. If you feel like it’s an unsafe place but you can’t move, call the police so they can close off the lane for you.
    Grumppy Thanks this.
  9. SmallPackage
    5,818
    18,640
    Dec 20, 2019
    Marion Texas
    And don’t forget there will be a few that will flame him for parking on the shoulder. Lol
    W923 and Flat Earth Trucker Thank this.
  10. Dave1837
    Dave1837 Road Train Member
    1,402
    4,349
    Nov 16, 2019
    Pennsylvania
    I recovered a trailer from the 2nd rest area on I-80 in Indiana, same thing happened to another driver. The company called a wrecker to chain the axle up and I ran it all the way back to Pittsburgh PA. Granted, that trailer was empty. I would've never done it with a loaded trailer, that'll add way too much stress on the fully supported axle and end up causing far more issues.
    Flat Earth Trucker and Grumppy Thank this.
  11. Numb
    Numb Crusty Curmudgeon
    4,352
    10,342
    Jan 30, 2012
    Charlotte, N.Carolina
    had that happen when I was a container yanker.
    company said drive on in to the rail head. 120 miles. loaded heavy.
    I chuckled and told dispatch ain't gonna happen!
    they sent a road repair out to chain up the axle and was again told "bring it on in"
    ummm.... nope, there's a closed convenience store about a mile down, I'll drop it there if it can't be fixed today, (which I knew wasn't going to happen with a container), and bobtail back.
    went back 2 weeks later to get it.
