TriPac Apu not sensing low voltage
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Jul 12, 2021.
  1. mitmaks
    mitmaks Road Train Member
    2,577
    2,093
    May 16, 2014
    My tri pac works fine except it stopped sensing low voltage ie it will drop below 12v and doesn't start to charge batteries. Only way to start it is to set it to a.c. and it will start and run fine.
    What could be the problem?
  3. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Could be the sensing wire by alternator white wire it use to be.
    They are known to break. not sure if you have older non evolution or newer. But check the sensing wire. Been years since I worked on the tri pak
    mitmaks Thanks this.
  4. mitmaks
    2,577
    2,093
    May 16, 2014
    Its old tri pac
  5. jason6541
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Also check to be sure your battery terminals are clean and tight and no corrosion. Might load test batteries as well
    See if they are any good.
  6. mitmaks
    2,577
    2,093
    May 16, 2014
    Last time batteries went bad it would start and attempt to charge them. One of batteries was swollen and apu ran non stop.
